A number of scans seeem to have lost resolution and i can now no longer register them. They have been fine all along and now are so pixelated i can barely pick any points of them, let alone cloud to cloud optimise. Deleting and bringing them back in doesnt seem to help either. Have i inadvertently saved them at a lower resolution? If so, how can i restore them?
Sam
Scene assitance required urgently!
- I have made 50-60 posts
- Full Name: Sam Lynas
- Company Details: PCL
- Aaron_Hazen
- Full Name: Aaron J.R. Hazen
- Company Details: Coast 2 Coast Surveys
- Company Position Title: Senior Project Manager - 3d Architecture
Re: Scene assitance required urgently!
If you did indeed save them at a lower resolution, then deleting them and bringing the raw .fls folders in will do the trick. Right click and load the scan before opening the quick view as well. It puts less of a work load on your cpu to do these steps seperately.
Always save and create scan point clouds for all scans to avoid this problem going forward. The scan point clouds will never lose resolution from being partially loaded and then saved.
Hope this helps
Hope this helps
- Full Name: Steve Bury
- Company Details: Bury Associates Limited
Hi Sam
Have you possibly been in Correspondence View first before going into Planar View? In Correspondence View you can partially load scans so they view more quickly, but if you then go into something like Planar View afterwards they are still only partially loaded so they appear at at much lower resolution. If you right click on your Scans folder then unload all scans then re-open them in Planar View, they will again appear at their full resolution.
