Faro remote - proof of concept
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Post by max72 » Wed Feb 24, 2016 4:29 pm
I have issues with my telephone with the wireless gui, so I decided to adapt some of my side projects to have a mechanical faro remote.
It's simply based on an RC transmitter-receiver combination and a servo.
Both parts work with a protected lithium battery, single cell.
The ugly setup is a combination of 3d printed parts, hot glue, duct tape and skewer pieces.
Seeing that it works next step will be to design and print a nicer and more stable adapter.
youtu.be/9oOX0gip5L0
Thanks for the inspiration offered on the site..
jcoco3
Full Name: Jonathan Coco
Re: Faro remote - proof of concept
Post by jcoco3 » Thu Feb 25, 2016 12:06 am
Even nerdier than zip ties and string :ugeek:
Looks like it works well, I bet the range is much better than Wifi!
Scott
Full Name: Scott Page
Post by Scott » Thu Feb 25, 2016 12:53 am
I like the piano-key 'hammer' concept...something I thought about at 3AM, some years ago. Once you perfect the mechanism, I'd be interested in the kit...sweet!
3DForensics
Full Name: Eugene Liscio
Skype Name: eliscio
Post by 3DForensics » Thu Feb 25, 2016 1:43 am
Double thumbs up from me. I love this kind of stuff!
max72
Post by max72 » Thu Feb 25, 2016 7:21 am
Thanks.
Zip ties show the spark of the genius.. and light the path
With my phone the wifi interface is not reliable at all.
In place of an RC chain it would be possible to use yet another wifi, or the bluetooth, but this looks to me like a much cleaner solution.
The trasmitter is a full range RC, so few 100s of meters:
http://www.hobbyking.com/hobbyking/stor ... odule.html
While it declares a 6-15V range it works with a single Li cell, at 3.7V, and even below. I have to test it full range to verify if the lower voltage affects it, in that case a 2s LiPo battery would be an alternative.
Post by Jason Warren » Thu Feb 25, 2016 7:54 am
Nice one.... ;)
cwxTools
http://www.cwxtools.com
High Definition Surveys Ltd
http://www.highdefinitionsurveys.co.uk
john-newbegin
Full Name: John Newbegin
Company Details: Travis County Sheriff
Company Position Title: Engineering Specialist
Post by john-newbegin » Thu Feb 25, 2016 7:01 pm
That is solid gold there.. I like that.. Much more reliable than hoping your connection works while your trapped in a concrete box 20 feet above the ground.
Thumbs up!
Scott
Post by Scott » Thu Feb 25, 2016 7:17 pm
I'd settle for a simple, compact, reliable, string activated twanger ;)
max72
Post by max72 » Thu Feb 25, 2016 8:09 pm
:-) I like it!!
For the moment I opted for a simpler solution. No more duct tape, still some hot glue.
WIth the new solution the remote fits the scanner and is very stable, a 1 second setup single handed.
I have to integrate a power switch and the battery charger.
youtu.be/1ptjmkcdJTc
jcoco3
Post by jcoco3 » Tue Aug 07, 2018 5:00 pm
Massimo,
Got to thank you for your contribution. We ran into some serious Wifi connectivity issues on a recent project where a cell tower that was very near to our work area prevented activation of scanning through wifi, but our Robot's RC transmitter and receiver was working flawlessly.
We simplified things a bit and used a tiny nano receiver and micro servo powered from the micro usb port on the scanner, so we don't have to worry about a secondary battery.
youtu.be/fQqh4BnjPvw
https://youtu.be/fQqh4BnjPvw
The really neat part is that we can bind multiple receivers to our transmitter so our robot can still be controlled by 5 of the 6 channels available, while the "remote finger" uses only 1 channel.
Return to “FARO”
