Trimble tx8 loses date in system
Discuss all Trimble related issues here.
kwiatu
Full Name: Jacek Kwiatkowski
Company Details: JL Consulting
Company Position Title: owner
Country: Poland
Skype Name: jkwiatu
Post by kwiatu »
Hi All
I'm a happy user of the tx8 - a while ago when I turned my scanner on the date in the system sets for 1 january 2002 :) I had 1106 firmware installed, updated to 1108 5 minutes ago and nothing helps. When you shut down the scanner after the correct date its set. After the reboot it goes back to 2002. It's pain in the ....:) becouse I need to name my projects starting with the correct date so I know when I was scanning. It started a few months ago, right now I have less work so I wanted to fix that but no ideas how to...
Anyone help...
Jacek
paranoiahasu
Full Name: ANIL
Company Details: Mergen3D
Country: Turkey
Has thanked: 6 times
Been thanked: 4 times
Re: Trimble tx8 loses date in system
Post by paranoiahasu »
Hi Jacek
First of all, I checked firmware versions and 1108 looks very old. Please check this link.
http://www.trimble.com/globalTRL.asp?na ... tion-99230
As you know computer systems using internal battery to keep date-time settings in firmware os (bios mostly). I checked manual but didn't find anything about date-time problems. Do you think this issue related with firmware?
apjokr
I have made 80-90 posts
Full Name: Robert
Company Details: Construsoft
Post by apjokr »
Dear Gents,
I inform you that the statement 1108 is old is not 100% correct. You may confused with the available 2028 version which exists but you need to know there are 2 models available from TX8.
For instruments with serial number 945xxxxx the 1108 is the latest FW.
For instruments with serial number 947xxxxx the 2028 is the latest FW.
Trimble needs to verify but I believe the issue is related to an internal battery which ran out and can be replaced during the calibration not by the user.
kwiatu
Country: Poland
Skype Name: jkwiatu
Post by kwiatu »
That's what I'm saying....
For instruments with serial number 945xxxxx the 1108 is the latest FW. My instrument serial starts with 945 so 1108 is the latest...
apjokr wrote: Tue Jul 10, 2018 11:10 am Trimble needs to verify but I believe the issue is related to an internal battery which ran out and can be replaced during the calibration not by the user.
So you are saying I need to send it to Trimble for calibration ?
apjokr
Full Name: Robert
Post by apjokr »
I am saying you need to contact your dealer support>trimble support to double-check and proceed if needed.
kwiatu
Country: Poland
Skype Name: jkwiatu
Post by kwiatu »
Thanks apjokr :) I'll do what u say....
ecrowe
Full Name: Eric Crowe
Company Details: WM3D
Company Position Title: WM3D
Post by ecrowe »
Did you ever find a solution to this? Having the same problem with mine.
apjokr
Full Name: Robert
Post by apjokr »
ecrowe wrote: Wed Jan 16, 2019 5:08 pm Did you ever find a solution to this? Having the same problem with mine.
Hi Eric,
The date/time information is operated by an internal battery what the user can not replace by their own, since it's under the hood and the unit needs to recalibrated when it has been opened up.
Up to the client if it's considered as a cosmetic issue to live with, or taking the effort to send the instrument to the service for this reason.
Robert
Return to “Trimble”
