Level Separation
BillyCRG
1
Full Name: William Peter Snyder
Company Details: Design
Skype Name: BillyCRG
Has thanked: 4 times
Level Separation
Post by BillyCRG »
I have a project that has three levels scanned in it and right now the SiteMap is pretty cluttered and confusing. What is the best way to separate out the levels in Reg360+ so that the SiteMap is more clear and usable? I guess on that note, what is the best way of showing multiple levels on one SiteMap so that anyone could look at this and know exactly what scans were on what level?
badam
3
Full Name: Adam Berta
Country: Hungary
Has thanked: 52 times
Been thanked: 315 times
Re: Level Separation
Post by badam »
Every sitem must includes setups from a single floor.
Register every floor separatelly then only move the setups required to register them.
So the solution is to use more sitemaps
For example, every floor has one and an addition exterior setups.
BillyCRG
1
Post by BillyCRG »
Ok, sounds good.
Peyman Bashiri
14
Full Name: Peyman Bashiri
Company Position Title: Laser scanning and BIM Specialist
Skype Name: pbashiri2003
Has thanked: 58 times
Been thanked: 41 times
Post by Peyman Bashiri »
I am unsure if Cyclone had this option but in ZF Control, you can group scans by several options including the elevation. The software uses the scanner barometer information for it.
Peyman
VisoProOskar
1
Full Name: Oskar Svensson
Company Details: VisoPro Sverige AB
Company Position Title: VisoPro Sverige AB
Country: Sverige
Post by VisoProOskar »
When scanning multiple floors, I usually use the
https://imgur.com/0UGY7pd
The button is up here when in the top view where you can see all your setups. I then choose the option in that menu to only show the last 7 or so setups. It helps declutter it a bit
Oskar Svensson, VisoPro Sverige AB
