Air Travel with RTC 360
- Full Name: Russell Lowry
- Company Details: Bi-Con Engineering
- Company Position Title: CAD Manager
Has anyone had to fly commercial with an RTC 360? Can you carry-on the bag and tripod? do you have to take the scanner out going through security? the thought of the scanner bouncing around on the rollers gives me chills.
- geomontgomery
- Company Details: ECE Design
- Has thanked: 20 times
- Been thanked: 48 times
Re: Air Travel with RTC 360
Hey Russ,
Never had a problem flying commercial with the scanner & tripod in the bag as carryon. You can store it overhead or below the seat in front of you, depending on the size of your flight.
Never took the scanner out of the bag through security. I've heard of others who were questioned through security and they just told TSA it was a camera.
- I have made 90-100 posts
- Full Name: Joe Nally
- Company Details: EPS
- Has thanked: 13 times
- Been thanked: 18 times
I was told to keep the batteries in a seperate bag once. Never had a problem since.
- Justin Richards
- Full Name: JUSTIN RICHARDS
- Has thanked: 38 times
- Been thanked: 51 times
I usually take the Faro scanners when traveling and they would flag them sometimes but I explain to TSA that it's expensive and fragile and guide them how to inspect it. I never had any issues. I take the carbon fiber tripod in checked bag and the bigger ones get shipped UPS. The batteries are fine, I've taken much bigger through TSA and checked bags no problem.
- Full Name: Jed Frechette
- Company Details: Lidar Guys
- Has thanked: 62 times
- Been thanked: 220 times
Similar experiences here. Tripods go in a hard case as checked luggage and scanner heads are carried on. I'd say 10-20% of the time TSA will want to inspect the scanner case but it's never been a big deal. Often they'll just open the case and swab what's visible without removing the scanner head from the foam.
The biggest thing is to keep ALL of your batteries with you in your carry on. Li-Ion batteries in checked luggage on a passenger plane is a big no-no.
- 1
- Full Name: Roy Candler
- Company Details: Delonix Solutions
- Company Position Title: Senior Reality Capture Technician
I fly very regularly with the RTC360, it's very nice being able to take everything carry-on and not worry about baggage handlers dusting/destroying the equipment.
One additional note is that the backpack, RTC360, a tablet and batteries comes in at about 12kg (26lbs). This is under the weight limits for most normal commercial flights but is well over the carry-on limits for small aircraft if you are travelling to regional/remote areas like mine sites. I've had very good success calling ahead and making sure your ticket flags the increased weight of carry-on and approves it, every now and then it becomes a drama during check-in.
I use the Nedo Carbonline tripods and those can be slipped into my normal checked bags. The Leica carbon tripod can also fit most luggage. 90% of the time the RTC360 will get flagged for inspection during x-ray because that thing straight up looks like a bomb .
- Full Name: Bruce White
- Company Details: Sterling Systems
- Been thanked: 3 times
Same here. Travel all the time no problem carrying on nor with TSA. Like others have said, "it's a 360 degree camera"
- Full Name: António Gomes
- Company Details: BuildGest
- Company Position Title: BuildGest
- Country: Portugal
Hello everyone,
Does anyone have experience flying the RTC 360 or even a Leica TS13 to the African continent in this case Angola?
Can you tell me what is the smartest way to transport this type of equipment? I am having some problems because of the batteries, I need to take extra batteries and I don't know how to do it....
Do you usually have any problems with the tax authority?
Thank you very much for your help
- Full Name: Dave Schaff
- Company Details: APEX 3D Scanning Solutions
Do any of you ever check your RTC360 hard case? I have traveled many times with the hard case as a carry-on and with the backpack as a carry-on, with no issues. I am curious what travel set up most of you are using as the backpack and the hardcase become heavy pretty quickly!
- Justin Richards
I would use the backpack so it can be stored under the seat and no worries about having to check it.daveschaff wrote: ↑Tue Jun 06, 2023 1:24 pm Do any of you ever check your RTC360 hard case? I have traveled many times with the hard case as a carry-on and with the backpack as a carry-on, with no issues. I am curious what travel set up most of you are using as the backpack and the hardcase become heavy pretty quickly!
