RTC360 at -5 to -20C
Justin Richards
3
Full Name: JUSTIN RICHARDS
Has thanked: 38 times
Been thanked: 51 times
Post by Justin Richards »
I need to scanner a freezer warehouse. I tried running a different brand scanner and was having issues with heavy distortion and fog inside the scanner that would freeze. There is almost no wind inside the warehouse and there is a 40F refrigerated and a 70F area to take breaks if needed. Does anyone have experience running an RTC360 in lower temp? I have 2 pairs of batteries for it.
TIA
Last edited by Justin Richards on Wed Dec 21, 2022 12:55 am, edited 1 time in total.
kpob46
I have made 100> posts
9
Full Name: Kyle OBrien
Company Details: Nutrien
Company Position Title: Mine Technologist
Has thanked: 18 times
Been thanked: 23 times
Re: RTC360 at -5F (-20C)
Post by kpob46 »
Funny you mention this. I had a similar situation last year when I had to survey some of our product when it was -35C. I only had our Faro S70 and managed to wrap it in bubble wrap to insulate it. Seemed to do the trick!
Can’t seem to rotate the stupid photo.
SlavikusAstana
3
Full Name: Vyacheslav Yurchenko
Company Details: ST-Vision
Country: Russia
Skype Name: Slavikus_Astana
Has thanked: 10 times
Been thanked: 14 times
Re: RTC360 at -5 to -20C
Post by SlavikusAstana »
The RTC360 scanned all day at minus 20 degrees without any problems, and even the batteries lasted almost the same time as under normal conditions.
Laser scanning, panoramic shooting
Desmodue
Full Name: Davide Pasina
Company Details: studio tecnico Pasina associati
Company Position Title: associato
Country: Italia
Skype Name: davide.playbike
Post by Desmodue »
I worked outdoors at about -10° C no problem
Leandre Robitaille
4
Full Name: Leandre Robitaille
Company Details: Cima+
Has thanked: 61 times
Been thanked: 246 times
Post by Leandre Robitaille »
Faro scanners have such a bad design for cold...
I had a project where they wanted me to scan in very cold (-30C) to see how big movements in the structure was compared to the hottest day in the summer. Issue was not cold, scan worked for 40 stations with no issues. I used this expensive lunch box that managed to keep the scanner above 10C internal temp threw out the 3hours I was there and the key is to turn off the fans in temperature settings.
Issue is the design of the lens, it has the condensation happen in the middle;
I tough having silica bags in the box would work but found out those have a shelf life. In order to scan I put my fingers on the windows to warm it up, then did a 1/4 2X scan with the premium (1min20s) and it managed to go threw, but that still wasn't great and results were all over the place and had to delete a bunch of scans.
Why does condensation need to happen in the middle where the lazer goes threw, why is it not on the sides like a normal window would?
masterpine
1
Full Name: Roy Candler
Company Details: Delonix Solutions
Company Position Title: Senior Reality Capture Technician
Post by masterpine »
RTC360 handles really cold conditions quite nicely. Just make sure the batteries (and spares) are stored in warm conditions, the unit will misbehave is the cells are too cold. I like to keep spares in my inner jacket pockets.
It may not help, but I also tape up air vents and gaps on the scanner.
