What processes do you do to judge the quality of the scan/scanner?
akeane
3
Full Name: Angus Keane
Company Details: BAE Systems
Company Position Title: Senior Dimensional Controller
Post by akeane »
Using Cyclone core for this, but I'm more proficient with realworks.
Suppose you've just gotten a brand new scanner and know nothing about it, what processes do you undertake to judge the quality of a scan and/or registration?
Previously what I've done in the past is scan a flat surface such as a whiteboard, granite surface, or a finished precast wall, and then take a horizontal cross section and look and the range of the bands of points. Ie i would expect in a 50mm thick cross section there would be <3mm variation of points (depending on distance), with the mean being the correct value.
I would see what the direct fit of an observation of 3 BW targets against the same 3 targets measured with a total station.
I would also inspect the .fls images from the instrument perspective to see if there is any obvious tearing.
To compare the accuracy of the overall registration, i would colour each scan by the station, then look at the overlap of the scan data to see if there is a strong correlation.
I'm sure there are other tricks; feel free to write yours below.
13
Has thanked: 627 times
Been thanked: 657 times
Re: What processes do you do to judge the quality of the scan/scanner?
In addition to the above I'd also consider the following (coming from a roads and topo background);
  • Check a level surface (as opposed to a flat one that may not be level) to check the compensator
  • Check sharpness of intensity returns, coloring by intensity and looking at something like road markings
  • Compare relative position of a road marking when coloring by intensity versus coloring by RGB to check camera alignment
  • Check noise levels on dark matt surfaces and dark shiny surfaces, some scanners struggle here
  • Check how easy it is to adopt external control
  • For mobile mapping, check the density and pattern of scan points, preferring parallel even spacing over scattergun patterns.
  • Check field to finish time, from starting to scan to having a clean, registered point cloud
Shane MacLaughlin
Atlas Computers Ltd
www.atlascomputers.ie
SCC Point Cloud module
akeane
3
Post by akeane »
Thanks Shane, this was very informative
