RTC 360 Extendable Tripod
joel.hicks
Full Name: Joel
Company Details: 4Z Pty Ltd
Skype Name: joel_4z
Post by joel.hicks »
Gday Forum,
can anyone please tell me what is the highest/mast/tripoid setup they have used for an RTC 360. That is stable, and does not return scans with vibration noise due to say the extendable mast section.
Grateful for your advice.
Joel
www.4z.com.au
Joel Hicks
Managing Director
4Z - Industrial Laser Scanning - Australia
Carbix
Full Name: Daniel Loney
Has thanked: 26 times
Been thanked: 30 times
Re: RTC 360 Extendable Tripod
Post by Carbix »
NEDO has been good to us for within 30m. Whats the range your working with?
Daniel Loney - Owner
Excelsior Measuring inc.
www.ExcelsiorLevel.com
Ronald Reuling
Full Name: Ronald Reuling
Company Details: Lantera BV
Country: The Netherlands
Has thanked: 8 times
Post by Ronald Reuling »
Hi Daniel,
Could it be that you meant 3 meters instead of 30 meters?
Kind regards,
Ronald
Ronald Reuling
Lantera b.v., The Netherlands
www.lantera.eu
Carbix
Post by Carbix »
lol yeah 3m
MajorDomo
Full Name: Major Domo
Company Details: VeritasVfx
Company Position Title: ceo
Country: Portugal
Has thanked: 11 times
Been thanked: 46 times
Post by MajorDomo »
The Nedo Line Shaft tripod gave me very good results with a P40 a few years back.It takes about 30 seconds to stabilise after raising to 6 ish meters from the ground.
I also used the KANGUR and I was less than impressed. The base flexes too much and it sways a lot more easily.
Mrk
I have made 90-100 posts
Full Name: Mark Lane
Company Details: LTS Lockley
Company Position Title: 3D Laser Scanning and BIM
Has thanked: 10 times
Been thanked: 22 times
Post by Mrk »
I often use the RTC360 with Nedo Shaft tripod with great results up around 5m. Of course you need to watch out for wind and overhead powerlines though. The great bonus to the Nedo Shaft is that you can also invert and go -4m down. Also get the dolly with wheels :like:
You should also consider an impact driver for hoisting the shaft, as hand-cranking gets pretty slow and tiring after a few hours.
Mark Lane
Sydney, Australia
TLS Tools
LTS Lockley
Ronald Reuling
I had the same question a while ago and did a little research.
Because I wanted a really sturdy tripod I came to the following sub-selection:
- Nedo: Tripod for machine control applications
- Ref.No. 210530 -> 3,10 m / 14,6 kg
- Ref.No. 210540 -> 4,01 m / 17,2 kg
- MQ-Statieven: Heavy Duty Tripods
- Ref.No. MQH255S130 -> 4,05 m / 17,2 kg
- Ref.No. MQH315S130 -> 4,645 m / 18,8 kg
Yes: None of them is a light-weight.
Eventually I bought the MQH255S130.
Here are the thoughts from my perspective:
My company car is a Volkswagen Caddy. And the MQH255S130 happens to really just fit in the loading space. When I close the doors the spare space is only about 1 or 2 cm. The larger Nedo and MQ are too long when folded together and unfortunately do not fit.
In general, I find the MQ tripods to be somewhat sturdier, more stable and easier to handle than those of Nedo. But Nedo is not bad. Far from that.
What I really liked about MQ is that there is a spindle at the bottom. This is easily accessible even when the tripod is fully extended. Please note the indication "S" (Spindle) because there are also other models available without a spindle at the bottom. This is not immidiately clear at their website.
Besides the very good plate foots (standard delivered) I also bought the point foots and the swivel wheels. The wheels are not cheap but very good. What I like is when you block the wheels, they will not roll AND will also not swivel any more. They are completely fixed.
MQ Statieven is a company that is situated in The Netherlands. I like their personal approach. If you want to have a “special” tripod that can be made from the standard components, they will make it for you.
Links to their webpages
- https://www.nedo.com/index.pl?Lang=ENGL ... ative.html
- https://www.mq-statieven.com/en/heavy-duty-tripods/
In both cases you have to click further from there to come to the tripods that I mentioned.
Mark Lane is right about a battery drill.
Just one last tip about that: Set the slipping clutch to “light” 😊.
Ronald Reuling
www.lantera.eu
