I want to ask how can I add a coordinates to my BLK360 point cloud?
Iam using Cyclone Field 360 and Cyclone Register 360.
For one building I need to cooperate with a surveyor.
I understood, that he will give me coordinates for the targets placed at the building.
I just do not know, where and how exactly to do that?
I will be very thankfull for any help.
Thank you so much.
have a good day.
A.
BLK360 and adding coordinates
- fototicha
- Full Name: Anna Leitao Ticha
- Company Details: Digitalizace Budov sro
- Company Position Title: 3D scanner operator
- Country: czech republic
- I have made 90-100 posts
- Full Name: Scott Ernst
- Company Details: Southwest Scanning
- Has thanked: 3 times
- Been thanked: 13 times
Re: BLK360 and adding coordinates
Take a look at this short video. https://www.youtube.com/watch?v=h8Jc18Rdd_w&t=2s
youtu.be/h8Jc18Rdd_w
- fototicha
Hi ScottErnst,
thank you very much.
The video was very helpfull.
I am going to test the theory in praxis tomorrow
Have a nice day.
Cheers.
Have a nice day.
Cheers.
Anna Leitao
- stutosney
- Full Name: Stuart Tosney
- Company Details: ---
- Country: London
- Has thanked: 25 times
- Been thanked: 58 times
This seems very long winded - so do you have to manually go through and rename every target in every individual set up? In Cyclone Core, once the targets are named it will automatically detect the same targets in multiple scans. This would be so time consuming if you have a large number of scans, is this the same for the RTC when adding control in Reg360?
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 148 times
stutosney wrote: ↑Wed May 05, 2021 10:58 amThis seems very long winded - so do you have to manually go through and rename every target in every individual set up? In Cyclone Core, once the targets are named it will automatically detect the same targets in multiple scans. This would be so time consuming if you have a large number of scans, is this the same for the RTC when adding control in Reg360?
The newest version of the software will automatically rename the same point in adjoining scans if you have C2C clouds in a bundle AND the targets are at least extracted/marked, but not labeled. This is because there is no "Naming process " for the targets on the scanner . The latest Field 360 app though allows you to tag the targets and name them in the field and Reg 360 software looks for those tags to auto mark and label targets on import, but then you have to go through the whole Scanner -Field360-Reg 360 workflow instead of straight from BLK360 Raw *.BLK files imported into Reg 360. If you've used find targets on import then they MAY already be tagged (along with other things that are not targets but the algorithm thinks it is (B/W adjacent colors like brick lines, overhead wires??)
If you are only using them to geo-reference then you can take the registered cloud and label afterwards. I usually label them all before registering them and can use them to aid in C2C - which we do a lot because most of our scans are outside for topo and verification purposes
- Full Name: Luis Miguel
- Company Details: Lmgumiel
- Company Position Title: Lmgumiel
- Country: España
- Skype Name: Lmgumiel
- Has thanked: 13 times
Hello, I don't know if it will be for the 2022 version, but it changes the X and Y coordinates. Does the same thing happen to you?
Documentación, Rehabilitación y Difusión del Patrimonio Construido
www.bitraze.com
www.bitraze.com
