Hi all.
Has anyone had/solved an issue where dialog boxes in Cyclone pop up off screen, as if it thinks I'm using a third monitor (I'm using two)? I can always retrieve it by using Shift+Win+Left Arrow but I'd rather just fix the problem. I thought this was just a glitch in my monitor setup, but I recently got a new computer and it happens with this one too. My current setup is just a laptop connected to a second monitor and the only way I've been able to fix it is if I just use a single monitor.
I'm using Cyclone 2020.1, but it happened with previous versions too.
Thanks,
Rob
Cyclone dialog box off screen
- Full Name: Robert Pfischner
- Company Details: Feldman Land Surveyors
- Scott.Warren
- Full Name: Scott Warren
- Company Details: WSP Canada
- Has thanked: 43 times
- Been thanked: 111 times
Re: Cyclone dialog box off screen
I've had it happen to me, and usually use the shortcut you mention.
Also happens with Jetstream Viewer sometimes, not sure why, but it seems fairly common when I'm switching from office to home and don't have my extra monitors.
- Full Name: Major Domo
- Company Details: VeritasVfx
- Company Position Title: ceo
- Country: Portugal
- Has thanked: 17 times
- Been thanked: 53 times
I've seen that on other software suites.
It ended up being ghost monitors.
https://superuser.com/questions/1142103 ... hics-adapt
Thanks for the responses.
Doesn't seem to be ghost monitors. The device manager only shows the two that I'm using.
I'll reach out to our Leica rep to see if they've got any ideas.
- I have made 90-100 posts
- Full Name: Cornelis Kolbeek
- Company Details: 3dszkennelés
- Company Position Title: Scan specialist
- Country: Netherlands-Hungary
Did you click "show hidden devices" in device manager where your monitors are listed?
That's a good thought. When I turned on hidden devices I found two more monitors listed, uninstalled them, rebooted to confirm they were gone, and checked Cyclone again. I'm still having the issue where the dialog boxes are popping up off the screen.
Rob
Rob
In that case i would make sure there are no hidden devices, then un- and reinstall cyclone. See if that helps.
