Current status/opinion of the BLK360?
mjankor
Full Name: Martin Ankor
Company Details: TasWater
Post by mjankor »
I've seen a bunch of criticism from around the release time about poor registrations, problems with Recap, and various other problems.
I've also seen some very average data, and some very decent data from the units.
Now that it's been out for a couple of years, has the situation improved? Does anyone have any recommended, bulletproof(ish) workflows?
Also, what else is out there in that market segment?
JonMag
Full Name: Jonathan Magal
Company Details: GeoMJ
Company Position Title: Géomètre
Country: Belgique
Been thanked: 8 times
Re: Current status/opinion of the BLK360?
Post by JonMag »
Hello, I use BLK360 for one year now and I'm happy with this unit if you consider its size and its price.
Most of the time, I use it for 2D as-built plans. Due to its size and weight, you can put it almost everywhere. You can take a scan in 40 seconds ([email protected]), it's sometimes enough; I prefer [email protected] : 1min40. I use it with an iPad Pro and the Field360 application. Recap for iPad is not good, it's an unfinished app.
Even if I'm happy, don't get me wrong, it has his limits. It's not RTC360 or S150plus or all the high-end units. But I think that it's a good device to start in the scan world.
For some work, I used paper targets that I had measured with my total station and the control is good (often 3mm error max).
If you have questions, feel free to ask.
Mike Annear
Full Name: Mike Annear
Company Details: Mike Annear
Has thanked: 41 times
Been thanked: 97 times
Post by Mike Annear »
Hi Martin,
Good to see you back !
It is a great scanner for the price . (emphasis on "for the price")
I have used it a lot for scanning boats, it is brilliant for that task, small, fast, good camera.
It is great for international travel, not that we are going to be doing any of that for a while :)
Cons.. I don't like Recap/Field360 , especially if you are used to old school Cyclone with proper site notes :)
The data is on the fuzzy side, if you are used to P-Series data it might be hard to adjust.
File transfer is awkward and slow.
No compensator to speak of.
You could hire one from Techrentals, they have a good fleet of scanners these days, but I don't think they have a Tassie office.
Francois is also in Tassie I believe, he might be able to get one for you to have a look at.
Mike.
Mike Annear
www.mikeannear.com
QLD, Australia.
mjankor
Post by mjankor »
Thanks Mike, Jon
What are the current registration options? Recap and Register360? Anything else?
VXGrid
Full Name: Martin Graner
Has thanked: 51 times
Been thanked: 56 times
Post by VXGrid »
mjankor wrote: Sun Jul 05, 2020 11:14 pm Thanks Mike, Jon
You can register with anything you just need to get the data in an exchange format.
To get the exchange format you can go via Leica or AutoDesk as mentioned above, meaning:
If you use the Ipad + ReCap, copy the files to your computer, open them in ReCap Desktop and save the project. If your registration software is able to import RCP/RCS files then you are good to go, otherwise you need to export it as an E57, so you need ReCap desktop Pro.
If you are going via Leica, you can either capture the data using the Ipad with the Leica app, or just by pressing the button and using the Desktopmanager tool from Leica to get the data out of there and then using Register360 on the Desktop. I think you can import the .BLK files in Cyclone as well but not sure. And from there export it as an E57.
If you want to use something beside ReCap / Register360, I'd go with ReCap --->pricing.
I've seen a registration done by Scantra with E57 data from the BLK.
Daniel wrote an article using the data:
https://www.linkedin.com/pulse/taming-e ... iel-wujanz
Brett
Full Name: Brett D
Company Details: Omega Geomatics
Country: England
Post by Brett »
Mike Annear wrote: Tue Jun 30, 2020 8:27 am File transfer is awkward and slow.
That is being generous!
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 230 times
Been thanked: 49 times
Post by gsisman »
Brett wrote: Wed Jul 08, 2020 1:56 pm
File Transfer From BLK to Computer is limited by the internal WIFI ability of the BLK. = SLOW (we average 3-5 min per Hi-res scan.
The iPAD Pro which is used for both Recap Pro Mobile (we dumped this workflow as soon as the BLK Data-manager became available) and Field 360 can speed some things up, but only if you are downloading the BLK scans to the iPAD while you are doing something else and then using Lightning to IP transfer to the computer (also Sometimes it's easier to align visual C2C using the the Field360 app than the Reg360 app (especially the profile tilt option. We are always scanning at full resolution scan and non-HDR when scanning outside (most of our scans are outdoors). That being said, our jobs are pretty small 12-40 scans and we ALWAYS shoot 3 visible targets from each scan -target placement planning takes some experience ,but once you've done it a few times it become back of hand. Most of ours are intersection scans, or small topos so we usually shoot reflectoreless to 4" BW Leica targets on poles or mag targets, which we have been able to extract at up to 70' on Hi-Res). We've been regularly hitting less than 0.10' in global and C2C registration residuals with this process.
Full Name: Chad Snoke Geopro
Company Details: Geopro
Post by [email protected] »
Sorry to resurrect a thread from the dead, but wanted to respond to the download speed is limited to wifi" comment, you can buy an USB-C adapter that has an ethernet port on it and plug the cat6 directly into an iPad Pro. Much faster transfer speeds.
When things get weird, the weird turn pro.
http://geopro.xyz
miguel.antunes
Full Name: Miguel Angelo Morais Antunes
Company Details: Engineering
Country: Portugal
Post by miguel.antunes »
I use BLK for almost 3 years, in the beggining was ok, now I only use for rooftops
hunenkonig
Full Name: Attila
Company Details: Private
Company Position Title: Team Lead
Post by hunenkonig »
Anyone know of a new product release?
Considering that the BLK360 was released in 2017 and is over 4 years old, what is the usual update or upgrade of firmware?
I've been looking at purchasing a second hand unit, any thoughts of what they are worth?
Much appreciate any replies.
