New to the scanning game and started out using Recap pro with our BLK360. Have now switched to Register 360. Once you have imported the scans and gone through the steps to hit "Finalize" it comes up with Bundle Error, Overlap, Strength, Cloud to Cloud and Target error.
See attached pic where all are green and seem pretty good, but what are the tolerances of each? At what point do they appear red or a different colour?
What does "strength" and "bundle error" actually refer to? Cloud to cloud, overlap and target error I get.
Tolerance in register360
- Full Name: Clint Stanley
- Company Details: RemSense
- Company Position Title: Scan Tech
- Scott.Warren
- Full Name: Scott Warren
- Company Details: WSP Canada
- Has thanked: 44 times
- Been thanked: 111 times
Re: Tolerance in register360
Yes, in your options for Reg360 you will be able to set what each of the 3 colors represent (Red, Yellow, Green). If your cloud to cloud links fell outside of the tolerance set for the 'Green' color band, it would be yellow, or red. These have default values, and many will edit these based on the tolerances they are looking to achieve.
A lot of this info is in the help, with a clear explaination of terms. also, there is a built in guide bar which explains may topics called "assistant" on the top right of the screenshot you have show.
