Black lines in RealView when importing into Recap - RTC360
Theodore Michel
Full Name: Theodore MICHEL
Company Details: Alpes Topo
Company Position Title: 3D acquisition manager
Post by Theodore Michel »
We recently acquired a brand new RTC360 laser scanner. We are getting some troubles when exporting the .e57 clouds from Register360 and then importing them in Recap, as the RealView shows us a lot of black lines, especially in the areas that seems to be the edges of the objects.
Has any of you ever had this problem before ? Do you know how to fix it ?
See the attached image to have an idea of the problem.
Thank you very much !
Theodore
pburrows145
Full Name: Paul Burrows
Has thanked: 20 times
Been thanked: 26 times
Re: Black lines in RealView when importing into Recap - RTC360
Post by pburrows145 »
What you are seeing is the mixed-pixel filter in action which gets rid of erroneous points (at the point of data import). When viewed from the scan-position, this looks like "cel-shaded" cartoon graphics.
You can reduce the aggressiveness of the filter in Cyclone/REG360 as you choose.
S_Franklin
Full Name: Skylar Franklin
Company Details: PacificRimMechanical
Company Position Title: ScanTech
Post by S_Franklin »
My RCP looks like that when I export E57s out of Register 360 then go and then Create the RCP. If you Create the RCP right out of Register 360 then the black lines go away.
KMack
Full Name: Kirsty Helen
Company Details: Shhhh
Company Position Title: Survey Technician
Country: New Zealand
Has thanked: 8 times
Post by KMack »
pburrows145 wrote:
Fri Jan 24, 2020 12:52 pm
How can you show 360 images in the realviews instead of point cloud?
pburrows145
I believe the next release of Cyclone/REG360 will support this with a renewed RCP export - but I need to get clarification.
Moc
Full Name: Matthias S
Company Details: TPI
Company Position Title: 3D-Team Coordinator
Has thanked: 4 times
Been thanked: 4 times
Post by Moc »
KMack wrote:
Wed Mar 11, 2020 12:51 am
Use Cyclone 9.4.2 and export directly to RCP. It works with panoramic photos.
