Leica HDS3000
Giassone
Full Name: Jason Charalambides
Company Details: Architectural and Engineering services
Company Position Title: Authorised representative
Has thanked: 8 times
Leica HDS3000
Post by Giassone »
Greetings from Baltimore,
I am an Architect/Structural Engineer and our small firm recently purchased a used Leica HDS3000. Alas, the equipment came without the Cyclone software that is necessary to operate it. It is an old version that we need so that we can operate this equipment which otherwise is about as good as a log of tree in our office. Can someone give us some help on that, please? Thank you!
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 165 times
Been thanked: 42 times
Re: Leica HDS3000
Post by gsisman »
Giassone wrote:
Fri Jan 03, 2020 5:05 pm
You can buy the software or purchase timed subscriptions (what we do) or hire out Existing users to register your data and export to you. We've done that process in reverse asking for Registered LGS foile or REg 360 projects that we then feed into our Jetstream Enterprise
Peyman Bashiri
Full Name: Peyman Bashiri
Skype Name: pbashiri2003
Has thanked: 4 times
Been thanked: 13 times
Re: Leica HDS3000
Post by Peyman Bashiri »
I suggest to call your local Leica rep. As far as I remember Leica stops support for 3000 and SS2 a while ago. Also new Cyclone may not support old tools like yours.
Has thanked: 110 times
Been thanked: 54 times
Re: Leica HDS3000
Post by Jason Warren »
Let me know your postal address and I will get it sent out to you... ;)
No additional Cyclone license is required to capture data with the HDS3000 hooked up to a field computer, e.g a GETAC V100 with a SSD drive ;)
However, to register the scanworlds together back in the office you will require a Cyclone REGISTER license for your workstation.
Giassone
Re: Leica HDS3000
Post by Giassone »
Thanks a Milion, Jason! My address is 5802 Kipling Ct. Baltimore MD 21212 USA. Gosh, this may save the whole deal!
Re: Leica HDS3000
Giassone wrote:
Sun Jan 05, 2020 7:47 am
Here to help,
Will post out first thing tomorrow morning via Royal Mail, and will let you know the tracking number so you can keep tabs on it... ;)
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Been thanked: 21 times
Re: Leica HDS3000
Post by SCCS RTC »
I told you the forum would help ;)
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
Giassone
Re: Leica HDS3000
Post by Giassone »
Thank you again Jason. Now to be on the safer side, would it be easier and safer if you emailed it to me if that is possible? Sometimes with mail, you cannot know what can happen to a CD. Perhaps you might want to send me a copy. Or maybe I am getting a bit "too careful." Anyway, I am so grateful. When I come to the UK I will have to bring you a Bourbon Whiskey!
Jason C.
Re: Leica HDS3000
Giassone wrote:
Sun Jan 05, 2020 6:37 pm
Jason C.
Sent via WeTransfer, as requested.
If you need anything else, let me know.
All the best,
Jason
Formula1982
Full Name: Stephen Ferrari
Has thanked: 5 times
Been thanked: 6 times
Re: Leica HDS3000
Post by Formula1982 »
General question...if I were to install an older version of Cyclone which has scan control built in (removed from later versions of Cyclone) would it be able to control scanners like we used to or would the firmware not be compatible now? The most modern scanner we've used with scan control was the C10, but does anyone know if scan control would work with a P40 or P50?
I really miss scan control, it's great for having precise control over your scanning which you miss if all you have is a small touch screen. It'd be great to know if scan control was still an option...and what it would work with!!
