Finding measurement and depth of the CORROSION
shubhamr66018
Full Name: Shubham Rawat
Company Details: Streamline Inspection Ltd
Company Position Title: 3D Laser scan and NDT assistant
Post by shubhamr66018 »
Hi All,
I was asked to do a training task to find the corrosion in the tank using a Leica geosystem scanner.
I use high resolution with .8 mm in the setting and did the scan, so can anyone please let me know why we use high resolution and what we can do with this high resolution? Because I was unable to find the depth of the corrosion in cyclone software.
Thanks!
Tookie
Full Name: Iain Took
Company Details: WMP
Been thanked: 5 times
Re: Finding measurement and depth of the CORROSION
Post by Tookie »
I have no idea but you will get more replies if you include a picture of the tank or scan data.
Has thanked: 45 times
Been thanked: 34 times
Post by Matt Young »
shubhamr66018 wrote:
Tue Oct 08, 2019 6:06 pm
Hi All,
Thanks!
You won't be able to acheive that kind of accuracy with a terrestrial scanner. It's a bit miss-leading that some terrestrial scanners even allow that kind of setting. With a high resolution scan+images from the scanner you could locate the area of the corrosion by +/- 5 to 6mm (depending on survey control methodology) but not the depth, unless it's very deep.
You would probably need to look at a metrology scanner for that type of application.
MajorDomo
Full Name: Major Domo
Company Details: VeritasVfx
Company Position Title: ceo
Country: Portugal
Has thanked: 7 times
Been thanked: 27 times
Post by MajorDomo »
Matt Young wrote:
Wed Oct 09, 2019 7:50 am
Hi All,
Thanks!
You can even get even tighter spacings than 0.8 on the P40, by setting a custom value. Useful for stuff that is very far away, and when you're in no rush to process that data, because it will clog up everything, everywhere.
About rust...well, let's assume there is a lot of sediment on the bottom of the tank:
If you had a scan of the interior BEFORE there were any deposits you could calculate the volume.
Or if it is a surface tank, you could scan the interior and the exterior and derive the volume that way.
Or use a dipstick and get it done in a fraction of the time and cost :)
shubhamr66018
Thank-you! so much guys.
I'm sure you could set it to 0.1 of a mm of you wanted to, but you would not achieve that.
shubhamr66018
Thanks, Matt
paul4Z
Full Name: Paul Donnelly
Company Details: 4Z Pty Ltd
Company Position Title: 4Z Pty Ltd
Post by paul4Z »
Scanning corrosion (or dents/damage) is best done with a portable hand scanner. Because corrosion has such an uneven, non-consistent profile using a hand scanner ensures that you get 100% coverage of the corroded area.
We use creaform HandyScan 700s for this and they work excellently and can achieve an accuracy of about 0.05 - 0.1mm.
Check us out: www.4z.com.au
