JetStream Error
danielmckague
Full Name: Daniel McKague
Company Details: Systems Group
JetStream Error
Post by danielmckague »
We have a Publisher Pro License and have set up a JetStream server. We have multiple scans on the server and can also pull them up in AutoCAD using CloudWorx. However, there are currently 2 scans which exported to the server with no error but when we try to open them in AutoCAD we get an error that says "Failed reading Workspace from JetStream project". Has anyone else encountered this issue? We have tried re-exporting them but it still throws the same error once we try to open it in AutoCAD.
geomontgomery
Full Name: George Montgomery
Company Details: ECE Design
Has thanked: 10 times
Been thanked: 12 times
Re: JetStream Error
Post by geomontgomery »
Hey Daniel,
If you want to share one of the jetstream projects with me that shows the error we can get Leica involved to see what may have happened during the publishing process.
Best Regards,
-George
dineshkimraj
Full Name: Dinesh Kimraj
Company Details: Facilities Construction Consultants Ltd
Company Position Title: Senior Reality Capture Tech
Country: Trinidad and Tobago
Has thanked: 29 times
Re: JetStream Error
Post by dineshkimraj »
danielmckague wrote:
Tue Sep 10, 2019 3:27 pm
I have noticed that we started getting this same error when we try to open a JSV file in Cloudworx through the LGS button. I think that we were able to do this before, but we cannot anymore. But pulling the cloud from the Jetstream itself works no problem.
I'm not sure if this is what you are experiencing. We have not found a fix for it though.
graham.watson
Full Name: Graham Watson
Company Details: Road Science
Company Position Title: Technical Lead - High Speed Data
Country: New Zealand
Re: JetStream Error
Post by graham.watson »
I have just had this issue. Though I can open the same file in the Jetstream viewer
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 102 times
Been thanked: 21 times
Re: JetStream Error
Post by gsisman »
dineshkimraj wrote:
Thu Sep 12, 2019 4:02 pm
Yep, It's a bug.... or a planned obsolescence move by Leica.
I wouldn't doubt that they are migrating everyone away from the Jetstream only and to LGS (basically identical to JSV, but carrying more info including Limit boxes, Geotags, Etc.) - which also requires the higher priced Publisher Pro to generate the files. Just experiment with the File sizes between both and you can tell that. Bot in Jetstream Enterprise and in the Portable JSV/LGS format. JSV probably i supported only in the Standalone Viewer mode now. Just my guess.
The newest version on Jetstream Viewer v1.6.1 also supports a lot of the older Truview functions, so it is pretty clear they are moving to the newer Pointcloud AND HDR picture supported web-service using the back-end Euclidian technology for the FAST views.
