Borrowing Licenses Limit
dineshkimraj
Full Name: Dinesh Kimraj
Company Details: Facilities Construction Consultants Ltd
Company Position Title: Senior Reality Capture Tech
Country: Trinidad and Tobago
Has thanked: 31 times
Post by dineshkimraj »
Good day all
Quick question...Is there a limit to the amount of times I can borrow and return a license in CLM? For example, borrowing of Jetstream Connector and Enterprise Licenses.
I know there's a limit with the amount of time we can rehost the licenses.
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 114 times
Been thanked: 24 times
Re: Borrowing Licenses Limit
Post by gsisman »
dineshkimraj wrote:
Tue Aug 20, 2019 7:00 pm
Good day all
I believe there is . Whether it is policy or not I don't know. But when we were trying to get ours set up we were moving it a lot to test different scenarios and we had to get something re-enabled by HDS support
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Been thanked: 12 times
Post by SCCS RTC »
There is no limit to borrowing a license locally. There is a rehost limit which can be reset with the help of HDS support.
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
dineshkimraj
SCCS RTC wrote:
Wed Aug 21, 2019 6:42 am
OK great. We currently have one license hosted on one computer (which acts as the license server), but the other computer can only access the register and cloudworx license, not the Jetstream Licenses. But if there is no limit to borrowing of licenses, then we can live with that.
Mark Francis
Full Name: Mark Francis
Company Position Title: Geomatics Market Segment Manager
Post by Mark Francis »
As Phil says, plus borrowing a license is permissible for upto 90 days. Once borrowed, you may disconnect from the network and take the license with you (like a node-locked license).
ericguizzetti
Full Name: Eric Guizzetti
Company Details: Construction and Engineering
Company Position Title: RealityCapture
Has thanked: 9 times
Been thanked: 6 times
Post by ericguizzetti »
Good day all
You can switch licenses 5-6 times before you will need Leica's help to reset
Eric Guizzetti
San Diego, CA
Insta: ericguizzetti
