Failed to optimize
winslowkr
Full Name: Kevin Winslow
Company Details: Olsson
Company Position Title: Surveying-Reality Capture-107 UAV Pilot
Failed to optimize
Post by winslowkr »
I am working on a large Reg360 project 1,050 setups. I realize that this is mostly above what the program is optimized for. I am now getting a "Failed to optimize the given bundle. Encountered numerical issues when attempting to solve."
The bundle is split between 7 sitemaps. I have applied control but removed it trying to fix the issue. I have imported the reg360 project into Cyclone core, but I am lost on how I can fix the registration in Cyc-core.
Any suggestions why this error is coming up and any idea how I might fix it so I can finalize this project.
Kevin Winslow
Surveying/Reality Capture/UAV Pilot
Olsson
Rlowry
Full Name: Russell Lowry
Company Details: Bi-Con Engineering
Company Position Title: CAD Manager
Re: Failed to optimize
Post by Rlowry »
got the same message yesterday on a small scan job (15 scans). I restored all the points I had cleaned (a combination of using the detect moving objects tool and some manual cleaning) I was then able to optimize. I'm still doing some testing to see if I can break it again to see what the root cause is...
winslowkr
Post by winslowkr »
Yep, I think I was getting over zealous with the point cleaning, this was the problem.
Kevin Winslow
Olsson
topogeo
I have made 100> posts
Full Name: piercarlo roasio
Country: italy
Been thanked: 13 times
Post by topogeo »
I used manual cleaning (visual points and / or points for C2c) on jobs with 100-200 scans (from RTC360 and BLK360) and I never had any problems finalizing.
I also restore deleted points.
I have NOT tried yet on eliminating moving points.
However, I can't export the RCP file :-(
Piercarlo
Carbix
Full Name: Daniel Loney
Has thanked: 20 times
Been thanked: 26 times
Post by Carbix »
Moving Object detection and clean is deleting the cloud to cloud data but not the intensity data. really dumb odd glitch. unless I'm missing something.
Daniel Loney - Owner
Excelsior Measuring inc.
www.ExcelsiorLevel.com
KMack
Full Name: Kirsty Helen
Company Details: Survey Technician
Company Position Title: Survey Technician
Country: New Zealand
Has thanked: 10 times
Post by KMack »
Did you guys have any further thoughts on this?
I just registered a project in cyclone core (60 scans) but the group would not optimize. I am theorizing that its about cloud to cloud overlap; my cloud had plenty of constraints but mostly target to target, sounds right after what you guys are saying above. Further more I deleted a load of points from the control spaces (trees). After disabling some cloud to cloud constraints it gave me the unable to optimize error message but would still let me register the cloud. It then reported errors of 13 mm but visually the cloud had misalignment which i measured to be 100 mm.
Has thanked: 230 times
Been thanked: 49 times
Post by gsisman »
winslowkr wrote: Tue Jun 18, 2019 3:50 pm I am working on a large Reg360 project 1,050 setups. I realize that this is mostly above what the program is optimized for. I am now getting a "Failed to optimize the given bundle. Encountered numerical issues when attempting to solve."
That's a lot of setups. I've had this error before and it has always had to do with removing too many C2C points
miguel
Full Name: Michal Gula
Company Details: SANWU
Country: Slovakia
Post by miguel »
Hey guys,
i got the same error. Restoring points helps, Just a little tip, make sure you are restoring cloud-to-cloud points...no need to restore visual points
