Leica Cyclone Field 360 App Error
pburrows145
Full Name: Paul Burrows
Has thanked: 8 times
Been thanked: 5 times
Re: Leica Cyclone Field 360 App Error
Post by pburrows145 » Mon Jun 03, 2019 11:51 am
Slewis33 wrote:
Fri May 31, 2019 8:54 pm
I do not see the value of using Field360 with the BLK360 vs using Recap Pro
For context we are a large General Contractor and I view the BLK as a scanner for simpler tasks and model checking. No as-builts, no large scale scan projects. I like it as a tool to check models and identify issues that might need a real scanner to come out and As-Built something.
A few reasons I prefer Recap Pro vs Field 360:
1. faster download times
2. IT blocks wifi connection to Field360
3. Recap Pro is easier to get to the final product of a Recap file
4. Don't see the advantage as everyone in our department has Recap Pro vs only our Reality Capture team has Register 360.
5. I see the BLK as our scanner to send out with anyone or assign to project teams. I don't want a ton of Register 360 licenses, not worth the cost vs Recap.
1. How so? Have you tried a lightning to Ethernet adaptor?
2. Easily remedied? Can you bribe IT? :lol:
3. Ok, if that's your requirement. REG360 now exports to RCP with the Publisher Pro if this is something you might be interested in... cost associated, but the option is there
4. I suppose if your eco-system doesn't play ball, that's understandable...
5. You only need 1 REG360 license for 5 x FIELD 360
:geek:
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 29 times
Been thanked: 7 times
Post by gsisman » Mon Jun 03, 2019 12:56 pm
:geek:
Paul your number 1 solution- is it possible? I was told it was still wifi only...
The pre-registration would be nice if it is more reliable than the ReCAP solution, but the new recap is supposed to be pretty good
I would have to see a comparison between the transfer times of the Pointclouds from the BLK to Ipad in the field comparing a high res scan for both Recap Mobile & Field 360 (since the latter also has to transfer the entire cloud to the iPAD.)
And then using the WiFi again to get the data into Reg 360.....we'll see
That would be my hesitation unless the Field360 app were able to take advantage of the full WiFi speed of the iPAD Pro which could range from 200-900Mbs depending on your Wifi Card in Laptop/Desktop
Anybody have some side by side benchmark testing on that yet?
pburrows145
Post by pburrows145 » Mon Jun 03, 2019 1:35 pm
:geek:
I did say "have you tried"... I'm just stating the theoretically possible, as both devices would be on the same network and discoverable. I have not tried this personally, I might add.
Slewis33
Full Name: Shaun Lewis
Post by Slewis33 » Fri Jul 12, 2019 1:39 pm
Sorry for such the late response, missed this earlier.
1. I have not and would be interested in learning more.
2. IT is tough
3. REG360 is great, we love it (except for a few minor things) but going from Field360 to REG360 to Recap is twice as long or even 3x vs Going from Recap to....Recap (we have publisher Pro)
4. 10-4
5. and you have to purchase another Publisher license to get to Recap. Our REG360 license are always in use.
Mrk
I have made 60-70 posts
Full Name: Mark Lane
Company Details: Convert3D
Company Position Title: BIM guy
Been thanked: 6 times
Post by Mrk » Sat Aug 03, 2019 7:48 am
Anyone else having issues logging into Field 360? I'm getting "Login Failed: We where (sic) unable to log you in. Please try again later".
I've tried several ipads, confirmed login details, updated app, updated iOS, and still no progress :cry:
Local support can't help either. Anyone from Leica know what the problem is?
Mrk
Post by Mrk » Mon Aug 05, 2019 7:43 am
Local support provided a solution...simply register your Cyclone EID with Cyclone Cloud.
Apparently you must login to Field 360 at least once a month or your account can be locked out.
pburrows145
Post by pburrows145 » Mon Aug 05, 2019 10:07 am
Correct, you register your EID's here: https://portal.cyclone-cloud.com/login once you have registered. You then use the same login details to access Cyclone FIELD 360.
