Leica BLK360 Tripod Adapter Unscrew
stutosney
Full Name: Stuart Tosney
Company Details: ---
Company Position Title: Geospatial Consultant
Has thanked: 8 times
Been thanked: 36 times
Re: Leica BLK360 Tripod Adapter Unscrew
Post by stutosney »
I remember when I first used a BLK, the top unscrewed and it had a thread to attach it to other mounts etc. However, when I changed company and tney purchased one, it would not detach without breaking it. I think it was an extra to have a detachable top
Amann
Full Name: Emmanuel Durand
Company Details: Amann Engineering
Country: CH
Post by Amann »
Just by a new adapter from Leica. It costs 100 bucks and will fit on any tripod : )
I have got three...
miqgio_2
Full Name: Giorgi Mikadze
Company Details: Engineering Idea
Company Position Title: Lidar operator
Country: Georgia
Skype Name: miqgio
Post by miqgio_2 »
dlouie wrote: Tue Dec 18, 2018 3:54 pm The adapter is held in by red loctite and can only be removed with heat. Remove the O-ring a the base of the adapter. Place the shaft in a vice firmly and protect it from scratching. Get a torch and heat the joint evenly and slowly. Don't heat the outside, heat the joint. Put on a pair of thick leather gloves that have good grip and heat resistance and start unscrewing it. Do a little at a time. I've successfully removed two easily without damage.
Good luck.
Hello, it unscrews to normal (counterclockwise) or to opposite (to clockwise)
Thanks in advance
