Leica RTC to Recap
Bstallan
Full Name: Ben
Company Details: BES Geo
Leica RTC to Recap
Post by Bstallan »
We are looking at buying a RTC and recently had a demo but we can not get the HDR images into Reacp.
We are currently using Faro scanners and have a client that request the scan data as a Recap project with photos in the 'bubble' views. We recently had a demo with the RTC and exported the data from Cyclone 360 as .PTG & .PTX but both formats come into Recap as a colored point cloud. What we want is the images (with the point cloud underlaid). Is this something that can be done?
I've attached a couple of screen shots:
Leica:
Faro:
Thanks,
Ben
jamesworrell
Full Name: James Worrell
Been thanked: 12 times
Re: Leica RTC to Recap
Post by jamesworrell »
Not sure if it is completely honoured - let me know - but if you export as E57, images might go with it .. PTG / PTX are points only .. but highly doubt it out of R360.
In Cyclone Core (as in not Register 360) - you can right-click at the Scanworld level and export E57 which can send images with point cloud .. not sure if Recap will respect them - never noticed that it did.
Then again - not sure how all this will play with the HDR imagery regardless.
There is somewhat limited value in Recap bubble views any more if you go with the LGS files and associated viewer - my 2c. Recap back in Revit et al - we usually create unified tiles anyway for performance so you end up wanting two files - a structured Recap file (for bubbles) and unified Recap for performance. If you are getting to that point - might as well do an LGS and unified Recap (we use FME Desktop to unify + tile from E57 -> unified Tiles -> Recap - painful). FME does have a Recap writer - but it seemed to want to go via LAS - figured we might as well short cut it.
Then again, I was somewhat disappointed with the Publisher Pro license requirement for LGS .. but if non-plug-in truviews turn up any time soon it might be mostly forgiven.
Also measurement tools could be improved ..
topogeo
Forum Supporter
Forum Supporter
Full Name: piercarlo roasio
Country: italy
Been thanked: 4 times
Post by topogeo »
I have your same need.
Provide customers with a Recap project where they can see (like Realview) the IMAGES (photos) taken from the scanner.
It is true that the E57 format contains the images (photos) .. but the one created by Leica (Register360 or Cyclone) is NOT fully read by Recap.
What you can see the RECAP, today, from E57 created by Leica is what you have (cloud of colored points ..beautiful ..but only a colored cloud).
I do not know if the fault lies with Leica (who writes the E57) or RECAP (who reads them).
In addition, often images (colored cloud that are received in RECAP from an E57 created by Leica ... are very bad (see image).
Many users have raised the issue on the forum of Recap but .. Autodesk does not do anything to solve ..
To avoid this problem, you can export from Leica to PTG or PTX. The images that are obtained in Recap are always and only colored clouds (.. as you have seen ..).
It would be nice if Leica exported DIRECTLY in RCS-RCP format (but I think it will never do it ... it has to sell us its viewer (or better .. the Publisher Pro to create the lgs files ..).
Piercarlo
Jamesrye
Full Name: James Rye
Been thanked: 10 times
Post by Jamesrye »
We have found that if we use the istar camera and a P40, the images almost always align perfectly and look great in RECAP. It's true that you have the 'black skies' issue in RECAP though. We would love to have the images with the point cloud underlaid, as it looks so nice for the client.
The majority of our clients want .rcp/.rcs and they specify it now in the tender documents.
Here is an extract from a recent tender document, specifying the deliverables:
Survey Outputs:
✓ Topographical Survey - DWG 3D CAD
Point cloud - RCS/RCP/LAS/XYZ/TXT (Combined processed Colour recap file including mirrorball / survey locations
✓ Drawings – AutoCAD / PDF
✓ Reports – PDF / MS Word
✓ Excel files - XLS/CSV file formats)
A clean up of the pointcloud will also be required to remove people and vehicles etc.]
pburrows145
Full Name: Paul Burrows
Has thanked: 15 times
Been thanked: 19 times
Post by pburrows145 »
As I understand it, REG360 currently exports e57 without the images (will be fixed in next release I believe), Cyclone should export them.
You could try...
Importing the REG360 Project into Cyclone and exporting from there
Importing the RTC360 data into Cyclone (avoid REG360) and exporting from there
Or you could send the customer the LGS file with JetStream Viewer (for which you would need Cyclone PUBLISHER Pro to produce these). ;)
If they have CloudWorx they could read the LGS file too (bonus!). :D
topogeo
Forum Supporter
Forum Supporter
Country: italy
Post by topogeo »
the problem of images from Leica to Recap is very important ...
could you not do this test? ;) :D
If we try, inexperienced users, the results can be unsatisfactory .. not for problems of software .. but because of our fault .. .. :oops:
Piercarlo
Bstallan
Full Name: Ben
Post by Bstallan »
Thanks for all the replies.
I didn't grab the RAW data from the demo but will request it now, run it through Cyclone and let you know what happens.
pburrows145
topogeo wrote:
Tue Nov 06, 2018 12:46 pm
Piercarlo
I could test this for sure, but would rather use the customer data... mine always works perfectly, of course :D
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Been thanked: 8 times
Post by SCCS RTC »
Bstallan wrote:
Tue Nov 06, 2018 1:28 pm
Hi Ben,
Did you get a demo through us here at SCCS?
If so, I can get you the data and help you get this into RECAP.
Phil
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
pcmarko
Full Name: Marco Costabello
Company Details: Dimensione Dinamica
Company Position Title: engineer
Country: italy
Post by pcmarko »
Hi All! has Leica solved the problem of exporting images in RECAP?
