Dual axis compensator VS IMU
b_clive
Full Name: Clive Bugeja
Company Details: ARC International Surveyors Ltd.
Country: Malta
Post by b_clive »
Maybe it's a stupid question but just out of curiosity:
What is the main difference between and dual axis compensator and the new IMU tilt? I found some reliable answers about the dual axis compensator but none that really made it clear about IMU. Also regarding the dual axis compensator Is it ever good practice to switch the compensator off?
pburrows145
Full Name: Paul Burrows
Has thanked: 20 times
Been thanked: 28 times
Re: Dual axis compensator VS IMU
Post by pburrows145 »
Consider a whole can of worms.
Now consider it opened... :lol:
smacl
Full Name: Shane MacLaughlin
Has thanked: 92 times
Been thanked: 111 times
Post by smacl »
pburrows145 wrote:
Tue Oct 02, 2018 9:19 am
Nice. Coffee spat all over my keyboard. Cheers Paul! :)
Formula1982
Full Name: Stephen Ferrari
Has thanked: 5 times
Been thanked: 6 times
Post by Formula1982 »
b_clive wrote:
Tue Oct 02, 2018 8:26 am
i'll answer the relatively easy bit of your question: I would keep the compensator on as standard unless its set up on a structure that isn't in a stable position. For example on an offshore platform or vessel where it's obviously moving under you. The compensator is pretty much always a good thing to have in most any other situation.
I'm going nowhere near the rest of your question about the relative accuracy of an IMU unit. :D
b_clive
Country: Malta
Post by b_clive »
Thanks, Formula1982 for your answer. That is what we usually do. The compensator is always on by default. We did once do some scans on an oil rig and we did switch off the compensator as well as you said. So what would happen to the data if for instance the compensator is off and let's say we are on the oil rig and during the measurement it starts to sway? Would that data be unusable? cause like I said we did have compensator off while scanning on the rig and the data came out pretty much normal.
pburrows145
As long as your scanner stays relative to the object in motion you should be fine: on a ship/oil rig etc.
If you have it on, and the object starts to move, that's when you will get a warning (with any scanners that have a real-time dual axis compensator ;) )
Formula1982
b_clive wrote:
Tue Oct 02, 2018 12:14 pm
Depending on what scanner and software you're using, the data should still be fine as long as you can toggle all the scans to 'unlevelled' before you start your registration.
You can be scanning on a boat with it pitching and rolling during the scans, but as long as the objects are moving together (ie the rest of the boat), then all the scans with the compensator off will look 'normal' and 'level' relative to the boat.
b_clive
Country: Malta
Post by b_clive »
Thank you, it’s pretty clear now :)
GavFoster
Full Name: Gavin Foster
Company Details: Offset Services Ltd
Company Position Title: Photogrammetry - Laser Scan
Post by GavFoster »
Over 650 views and no answer. Is this another feature we think we need but don't know what it does ? :D
tbwester
Full Name: Thad Wester
Post by tbwester »
If you don't know if you need it, then you don't need it :)
On Leica machines, the DAC is incredible accurate and allows for precise level over very long distances. It also can clean vibrations from the scan (if scanning on a vibrating floor).
For MOST scanning folks on MOST projects, there is a little or no difference in the two techniques. And even if there is a difference, very very very few projects ever even need the accuracy of a DAC.
