Leica RTC360 Reality Capture Solution
- Full Name: Ioannis Papas
- Company Position Title: CEO
- Country: EU
- Skype Name: -
- Has thanked: 3 times
- Been thanked: 6 times
Re: Leica RTC360 Reality Capture Solution
Can you please calculate for us field time per set up and after you finish the registration the total office time ?
- Full Name: James Rye
- Been thanked: 9 times
Just following up on my earlier post, whilst the image detail and quality is great, the automatic tone mapping is not optimised well. Below, you can see one of the 360's had a weird purple hue (left) - I was able to manipulate this in Cyclone by clicking on the scan and going to "tone map pano image". It's worth noting that most of the images did not exhibit such a weird hue. It's really where there was a big difference between light and dark areas that they needed adjusting under the "Reinhard" tab to lighten up and reveal the data in the darker zones.
On the plus side, I used the vis and cloud alignment to register the 53 scans together (small project). I had surveyed a chunk of road around 300m long. Control points were at the beginning and end, with two in the middle. The control was levelled in. Pretty pleased with that. I also had targets in my scans, so will re-register using those to see if the plan accuracy improves at all.
- steves01x
- Full Name: Steve Smith
- Company Details: Scanning
- Country: Scotland
- Has thanked: 5 times
- Been thanked: 7 times
jmiller2103 are you using VIS when your getting the issue in Cyclone, if not how well have people managed to scan (no colour, no VIS)then importing straight to Cyclone Register?
)jmiller2103 wrote: ↑Tue Nov 13, 2018 3:19 am
A Major bugbear that we are finding in numerous jobs is that on import into cyclone register the scans are coming in at an angle whether its 10,45 or even at 90 degrees we have had them all. We have tried deleting and re importing all the way back to the raw but with the same result. The only way then to fix this is with the old fashioned 3 point pick in that lovely wizard.
Jay
- Full Name: Jay Miller
- Company Details: Madigan Surveying
- Company Position Title: Surveyor draftsman 3D modeler
Steve,steves01x wrote: ↑Thu Nov 15, 2018 3:49 pmjmiller2103 are you using VIS when your getting the issue in Cyclone, if not how well have people managed to scan (no colour, no VIS)then importing straight to Cyclone Register?
Jay
yes we always leave the VIS on because I believe this speeds up registration dramatically even when the scans are angled. I must admit since this post, both jobs I have completed I have not had this angled scan problem, both have been small jobs less than 50 scans, but jobs with more than 150 we usually get a few angled ones.
Whilst I am here I would like to ask a Leica Representative to please look into importing registrations into each other within core cyclone register, when I say this I mean when importing one registration into another, say you scanned on different days and you wish to make a c2c between these two registrations you get an ungrouped registration come across when you import it into your previous days registration( when previously it was in one group), this makes the combining of the registrations messy, especially when you have larger jobs over two weeks and a lot of ungrouped scans. It is a lot neater and easier to follow when there is one group. I do not know if it is an easy fix but for one registration to be imported into to another and remain grouped so then a simple c2c can be done and simply merge two days of scanning into one group.
- Full Name: Stuart Buckett
- Company Details: Airscope
- Company Position Title: Head of Terrestrial Scanning and Survey
Is anyone else having issues with the RTC360 Data Slowing Cyclone down to a snails pace?
Anything after 150 scans Cyclone becomes un-usable almost, only in that registration...
Our standard is Full Res Scans with imagery and about 150+ scans a day (4.2gb per scan)
ive just finished registering 600 scan project of and offshore platform and it took way too long (2 days)
i can normally get P series data registered for every 100 scans in about 2 hours so we normally register the same day as capture and add to a master registration.
Computer Specs arent the issue.
7700K processor with GTX1070 and 64GB of RAM
I do like the RTC360, its a shame its still riddled with issues, and cyclone has more Bugs now than 10 years ago...
jmiller2103 wrote: ↑Fri Nov 16, 2018 12:15 amSteve,steves01x wrote: ↑Thu Nov 15, 2018 3:49 pmjmiller2103 are you using VIS when your getting the issue in Cyclone, if not how well have people managed to scan (no colour, no VIS)then importing straight to Cyclone Register?
Jay
YES!!! im experiencing the same issues with Grouping of registrations
- steves01x
- Country: Scotland
Are days 01 and days 02 scans both grouped in their own registrations? If so when you import one in to the other, one will go to the ungrouped folder, use the visual align on a few overlapping scans, optimise etc then freeze / open new model space and they should all be registered?
With the speeds people claiming, i can see some jobs allowing for 150 to 200 set ups per 8 hours so the 3 point click will be a nightmare!
- Full Name: Fabien
- Company Details: Amec Foster Wheeler
- Company Position Title: Geomatics Project Manager
I have done close to 50 scans in less than 2hrs with the RTC360, so yes it's possible to do 150 to 200 scans in 8hours, the plus is they all can be pre registered. That will be at least 500GB file on import, which will take forever when you are not at the office, using a laptop and external Hard Drive.steves01x wrote: ↑Fri Nov 16, 2018 8:49 amAre days 01 and days 02 scans both grouped in their own registrations? If so when you import one in to the other, one will go to the ungrouped folder, use the visual align on a few overlapping scans, optimise etc then freeze / open new model space and they should all be registered?
With the speeds people claiming, i can see some jobs allowing for 150 to 200 set ups per 8 hours so the 3 point click will be a nightmare!![]()
- steves01x
- Country: Scotland
500gb with or without colour?Scan-Ninja wrote: ↑Fri Nov 16, 2018 2:10 pmI have done close to 50 scans in less than 2hrs with the RTC360, so yes it's possible to do 150 to 200 scans in 8hours, the plus is they all can be pre registered. That will be at least 500GB file on import, which will take forever when you are not at the office, using a laptop and external Hard Drive.steves01x wrote: ↑Fri Nov 16, 2018 8:49 amAre days 01 and days 02 scans both grouped in their own registrations? If so when you import one in to the other, one will go to the ungrouped folder, use the visual align on a few overlapping scans, optimise etc then freeze / open new model space and they should all be registered?
- Full Name: Fabien
It was with Color.steves01x wrote: ↑Fri Nov 16, 2018 3:03 pm500gb with or without colour?Scan-Ninja wrote: ↑Fri Nov 16, 2018 2:10 pmI have done close to 50 scans in less than 2hrs with the RTC360, so yes it's possible to do 150 to 200 scans in 8hours, the plus is they all can be pre registered. That will be at least 500GB file on import, which will take forever when you are not at the office, using a laptop and external Hard Drive.steves01x wrote: ↑Fri Nov 16, 2018 8:49 amAre days 01 and days 02 scans both grouped in their own registrations? If so when you import one in to the other, one will go to the ungrouped folder, use the visual align on a few overlapping scans, optimise etc then freeze / open new model space and they should all be registered?
