Slightly off topic - but why such a need for capturing imagery? The intensity data is up there with the P series.
I would rather avoid it but the jobs that do need it, i-star (assuming its not crashing) allows for quick capture and fairly easy import to Cyclone , avoiding any overly large files, not slowing up in the field too much or clogging the scanner up.
If you are needing very high resolution imagery then an external camera kit or a separate photogrammetry job is surely a better option both with full control over the camera etc? Or with the new LGS being able to insert tagged images where a photo is required?
Anyway, although not used the RTC yet if the size of the HDR imagery is the only issues with the work flow then its not too bad an issue until you hit a 500+ scan job in full colour.
jamesworrell wrote: ↑Thu Oct 25, 2018 2:13 am
Given some of the above tasks can easily take 24 hours + it is not realistic to use Register 360 - we can't afford to tie licenses up that long.
It would be rather handy if Cyclone allowed you to import Leica scan data with out a license and then just be able to open/view each scan that has been imported. Export is a pain as until you can batch export individual scans with their original names then its a fairly manual task and not an automated over nighter.
