Hi
how I do it is followed for registration done in a different software and applied into Scene
Export a PTX file with almost 0 points in it so you just have the PTX header
You can import this PTX file into Scene and if it has the same name it will import it as ..._0. Then use the registration and move it over to the scan position and activate the transformation.
The whole process takes about 4 clicks per scan in scene.
If the scantaxi APP would work with registration information done by other software pagages that would be good. I will have look into this once I find some time .
Andrej
Individual scan transformation data
- Full Name: Andrej
- Company Details: Meixner Vermessung and Freelancer
- Full Name: Stefan Wachsmann
- Company Details: scantaxi.de
- Company Position Title: supervisor
Re: Individual scan transformation data
Andrej,
give me the Format descriptions and I will take a look
At the Moment, I am working on the SCANTRA Import...
Stefan
Stefan
- Full Name: Andrej
Hi Stefan,
the format will be the header of the PTX file. Name of the scan same name as in Scene *.PTX. Non of the sensor will be used in scene.
I haven't found a better way out of Realworks and Cyclone yet as using the PTX export with almost no points in it.
Why can't they create import export of registrations???
TAndrej
TAndrej
- Full Name: Ivan Borisov
- Company Details: Vertex3D
- Company Position Title: LTD
- Country: Russia
- Skype Name: mastodont87
Hello to everybody!
In my project I found out the Recap did a better registration job with "cloud to cloud" technics than Faro Scene.
To continue work on the project with AS-Build in Autocad sofware I would like to make my SCENE project with same location of each scan as it in Recap.
Is there any way to export transformation data from Recap to Scene for my project?
Thanks in advance!
Ivan
Thanks in advance!
Ivan
