Cyclone : pipe run
pmadec
Cyclone : pipe run
Post by pmadec »
I have a little problem when I use the pipe run tool in Cyclone.
The point is that after recognizing the pipe, when I press ok in the dialog box, the pipe doesnt appears...
I have checked that all objects were visible, so the problem can not be solved by this way.
Also, all other modelized objects are visible after their creation.
Has thanked: 45 times
Been thanked: 34 times
Re: Cyclone : pipe run
Post by Matt Young »
Pipe Run tends to have about a 1/10 chance of modelling the pipe correctly. Personally, I would not use it.
Region growing the straight sections of pipe and then fitting elbows is much better.
To get the elbow's bend ratio, region grow it - then check the properties of the grown elbow. Then undo the grown elbow and fit an elbow with the recorded ratio.
Hope this helps
Matt
bc911
Full Name: Cerpentier
Company Details: Leica Geosystems Benelux
Company Position Title: Support
Post by bc911 »
Did you check that all the layers are on? If the current layer is not visible, you will see the pipe during the 'pipe run', but if you click 'OK' the pipe will not be displayed.
Press 'Shift + S' and check in the tab 'Layers'.
Maybe this helps.
Regards, Bert
Has thanked: 89 times
Been thanked: 42 times
Post by Jason Warren »
top tip Bert... :O)
