Skip registration on Cyclone Register 360?
Darius_bd
Full Name: Darius Blackdeer
Company Details: ---
Country: Chile
Post by Darius_bd »
So I'm a Recap user and when creating a new project one can skip registration. Is such thing possible in Cyclone Register 360? I cant find any option for that and the "finalize" button is grayed out (I guess is expecting me to register everything).
I just simply want to put all my BLK360 scans into one E57 file without using Recap. I think I can only do that with CR360 but these are standalone scans, not related one another. Does anyone has any idea how to do this?
Thanks!
geomontgomery
Full Name: George Montgomery
Company Details: ECE Design
Has thanked: 10 times
Been thanked: 12 times
Re: Skip registration on Cyclone Register 360?
Post by geomontgomery »
You could create multiple sitemaps in Reg 360 before exporting. Reg 360 expects a bundle in a sitemap, that's why it's not letting you finalize.
But for what you're doing, you might want to just import into a Cyclone IMP, then export the imp to e57.
Darius_bd
Country: Chile
Post by Darius_bd »
Thanks for your help! Indeed, after adding each scan (45) to a different site map it let me "finalize" but then I have to do a publish for each scan. UGH!. Is there a way to just make a bundle of randomly registered scans by chance?
Or, what software are you showing there? And how would be the workflow from the BLK 360 to E57? I guess you rather mean to export (from Register 360?) to an IMP and import it into... Cyclone what?
Tookie
Full Name: Iain Took
Company Details: WMP
Been thanked: 5 times
Post by Tookie »
Darius_bd wrote:
Fri Feb 01, 2019 7:14 pm
You can put the BLK data straight into cyclone and then export from there.. you might have to do the scans individually there though.
geomontgomery
Instead of cyclone register 360, there's another program called "Cyclone" that lets you do more stuff. With a license of Cyclone Register, there's some functionality you have access to in Cyclone. This link shows the feature matrix for your reference: https://leica-geosystems.com/-/media/Fi ... 78A3C651BA
So with Register, you can export e57 in Cyclone.
Here's a gif on how to create *imp file in Cyclone, and get to the BLK360 import, either directly off the scanner, or from the *.blk files. https://gfycat.com/HardGlisteningKoodoo
Darius_bd
Country: Chile
Post by Darius_bd »
Many thanks to both of you!
I got to say, I think of myself as a techie geeky but seeing how difficult is to put a licence into Cyclone made me wonder that I got pampered by easy to use software such as Autodesk family. Pretty much just download and run. I'm having a hard time trying to make Cyclone do more than just a viewer, and I'm not even sure that can be done with a trial licence of Register 360...
So, if I may ask, is there a straightforward way to make scans with my BLK 360 and end up with one e57 file with all the scans done, without using Recap? And ideally, without buying additional software/licences?
If there's no option but to use Cyclone, can I do the BLK360->E57 with a trial licence? I want to test that it works before paying more money...
geomontgomery
Darius_bd wrote:
Fri Feb 01, 2019 8:01 pm
Cyclone is the best way to go to from BLK > E57, since you're not registering. I need to correct an earlier post I made - Cyclone REGISTER 360 does not unlock the functionality you need in Cyclone, only Cyclone Register will. I'd suggest getting a trial of Cyclone Register, instead of Register 360 for what you are wanting to accomplish. Cyclone Register also allows you to use that same license to run Register 360 as well.
Darius_bd
Country: Chile
Post by Darius_bd »
Ah perfect! That would explain why I was failing at making Cyclone to work. It's a bit confusing all the progressive names for different apps, even more when Cyclone itself runs with different modules... Leica, streamline your software!
A thousand thanks for bearing with me! Actually your gif makes it look very simple, specially if no registering is included. (Tho I guess the scans will be indexed?)
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 125 times
Been thanked: 30 times
Post by gsisman »
geomontgomery wrote:
Fri Feb 01, 2019 7:47 pm
George and Darius
We had the same workflow and growing pains going from ReCAP to Register 360
First I think the Leica Matrix is a bit mis-leading.
The Register 360 Software comes with a Cyclone Basic license also (Reg 360 is an Add-on to that on the Licenses server or local License manager)
The basic license is essentially a viewer and allows virtually no functionality outside of that UNLESS you have a Publisher license or Publisher Pro License ($2K/yr - which then lets you output formats: Jetstream Local-Truview local, LGS and other Enterprise server formats).
You may be able to Import the BLK360 files into Cyclone Basic and then export them individually, but not sure you can do them in bulk. I think I tried that already. Cyclone Register will set you back $10K versus a year subscription on Reg 360 for about $2K
One work around could be this:
If you have Autodesk Products, make yourself a grid of 45 points in CAD with separation between the points, Take a snapshot of it and use the screen shot as a back map image in a NEW Site map in Register 360. Since you have all the Scans separated in separate site maps you should be able to drag them into the new site map one by one and place each one over a Control point on the image background
If your 45 BLK scans are on there own coordinate system each (not relative to each other or immaterial to each other)-you can create an export text file of those 45 points from CAD (*.CSV with PtNo,N,E,Elv, D) one point for the scanner head position of each scan-,then import the control file into that NEW site map that has all 45 scans -each scan has to have a virtual control point matching the point number of a point in the control file. Register 360 allows you to export multiple SiteMaps/Bundles (in this case your "Bundle" is ONE scan) IF the sitemaps/bundles are registered to the SAME control file.
You SHOULD be able to export them all as separate *.E57 files or one Bundled *.E57 file
I have not personally done this yet ,but it is on my testing listand theorateically should work
Someone needs to come up with just a simple *.BLK file to *.e57 converter which would eliminate a whole lot of workflow headaches with the BLK. BUT, that would allow us NOT to have to have Leica software for importing raw data into processing software.......which is no-where on Leica's radar
