creating point cloud in Recap from Cyclone
3DVEM, Leica Cyclone, FARO Scene, LFM Suite, Autodesk ReCAP, Riegl RiScan Pro, Trimble RealWorks, Etc.
TShock
Full Name: Tracy Shockley
Company Details: Engineering and Facility Analysis
Company Position Title: Sr AutoCAD Specialist
Post by TShock » Wed Mar 13, 2019 2:37 am
Hi, everyone,
I currently use an RTC360 with Cyclone to register my scans. Everything goes great and we have very little issue with scans. Where we are running into a snag is when we import the e57 file into Recap to create a point cloud. We get some trashy mirror balls - everything is streaky and or pixelated to the point where we can't see anything. It happens to at least 2 setups per site. We have recreated the Recap file to see if it helps and it does not. Any suggestions or ideas? I am at my wits end. Please see image below for example. Thanks, all!!!
pburrows145
Full Name: Paul Burrows
Company Details: Leica Geosystems UK Limited
Company Position Title: EMEA Business Manager HDS
Skype Name: pburrows145
Re: creating point cloud in Recap from Cyclone
Post by pburrows145 » Wed Mar 13, 2019 9:34 am
There will be a fix for this in due course, until then, you will see the issue. I am not sure if this is on our side, or Autodesk's... either way, it is being worked on. In addition, we will support export to RCP (minus images initially) shortly which I am sure many of you will welcome.
topogeo
Full Name: piercarlo roasio
Country: italy
Post by topogeo » Wed Mar 13, 2019 10:30 am
It seems ch in April we will have many interesting news in Cyclone :D
Today :
After many tests ... I found, as a better solution, the export of PTG. In Recap there are NO problems with the image
  "realview". You will NOT have the real photographic image but only the colored cloud ... but of excellent quality ..
If instead you give up the "Realview image" you can bring from Cyclone to PTS and then import it into Recap with 10mm decimation. Get a much lighter project ..
Piercarlo
TShock
Post by TShock » Wed Mar 13, 2019 11:43 pm
Thanks for all of the input - I am excited to try your suggestions...and I am especially looking forward to the update in April as it appears to have answers for a couple of issues that we have. I appreciate you guys!!!
