I'm looking for as simple tool that would analyze E57 scan files quickly. Most important information would be just a number of scans in the file, also the scan names. Its not necessary to display cloud at all. Any tips?
Currently using CloudCompare, FME and ReCap in general, but these are too heavy for the simple task.
Br,
Jukka
Simple tool to analyze E57 files
- Full Name: Jukka Alander
- Company Details: Forum Virium Helsinki Oy
- Company Position Title: Technical Expert
- Country: Finland
- Has thanked: 8 times
- Full Name: Juha Heikkinen
- Company Details: Neopoint Oy
- Company Position Title: CEO
Re: Simple tool to analyze E57 files
We are having the same problem.
The problem is that when you export several scans from cyclone to one e57 file. Cyclone gives new names for all the scans.
Br,
J
Br,
J
- Full Name: Scan ku kaï
- Company Details: Scankukai
- Country: France
- Has thanked: 58 times
- Been thanked: 207 times
We have the tool you need!
The separate scan converter we did for our software, Scansap, shows the e57 information and its structure.
No need to convert.
I can send it to you.
Please let me know.
No need to convert.
Please let me know.
- Full Name: Jed Frechette
- Company Details: Lidar Guys
- Has thanked: 62 times
- Been thanked: 220 times
You can use the e57xmldump utility that comes with libe57 to extract all of the header info to a xml file and then read whatever you want from that.
http://www.libe57.org/data.html
Although it's more aimed at extracting the data points rather than metadata, you might also be utilize the new support for e57 that was added to PDAL in the latest release.
- Country: France
Here's our e57 converter interface. We also use the e57 lib.
- Daniel Wujanz
- Full Name: Daniel Wujanz
- Has thanked: 206 times
- Been thanked: 188 times
Alternatively, you can also show E57 meta data in CloudCompare. Yet, you cannot change entries (if I'm not mistaken). A lot of programmers simply add default values to it that can cause trouble. Click on the small triangle in the project tree next to file structure. You can also have a look at pre-orientations and the like (pose --> translation & rotation).
Daniel
Daniel
- Country: Finland
Thanks, this is just what I was looking for - simple GUI program that anyone can use.
- 1
- Full Name: Amir Mizrachi
- Company Details: onsight
- Company Position Title: CTO
- Country: Israel
