Simple tool to analyze E57 files
Please post any tips or advice you have in general relating to laser scanning either whilst onsite or office based.
jukka.alander
Full Name: Jukka Alander
Company Details: Tietoa Finland Oy
Company Position Title: Project manager
Country: Finland
Has thanked: 4 times
Post by jukka.alander »
I'm looking for as simple tool that would analyze E57 scan files quickly. Most important information would be just a number of scans in the file, also the scan names. Its not necessary to display cloud at all. Any tips?
Currently using CloudCompare, FME and ReCap in general, but these are too heavy for the simple task.
Br,
Jukka
megafoni
Full Name: Juha Heikkinen
Company Details: Neopoint Oy
Re: Simple tool to analyze E57 files
Post by megafoni »
We are having the same problem.
The problem is that when you export several scans from cyclone to one e57 file. Cyclone gives new names for all the scans.
Br,
J
yankoch
Full Name: Yan Koch
Company Details: TagLabs
Has thanked: 10 times
Been thanked: 41 times
Post by yankoch »
We have the tool you need!
The separate scan converter we did for our software, Scansap, shows the e57 information and its structure.
No need to convert.
I can send it to you.
Please let me know.
jedfrechette
Full Name: Jed Frechette
Company Details: Lidar Guys
Has thanked: 6 times
Been thanked: 31 times
Post by jedfrechette »
You can use the e57xmldump utility that comes with libe57 to extract all of the header info to a xml file and then read whatever you want from that.
http://www.libe57.org/data.html
Although it's more aimed at extracting the data points rather than metadata, you might also be utilize the new support for e57 that was added to PDAL in the latest release.
Jed
yankoch
Full Name: Yan Koch
Post by yankoch »
Here's our e57 converter interface. We also use the e57 lib.
Daniel Wujanz
I have made 70-80 posts
Full Name: Daniel Wujanz
Company Details: technet GmbH
Has thanked: 13 times
Been thanked: 24 times
Post by Daniel Wujanz »
Alternatively, you can also show E57 meta data in CloudCompare. Yet, you cannot change entries (if I'm not mistaken). A lot of programmers simply add default values to it that can cause trouble. Click on the small triangle in the project tree next to file structure. You can also have a look at pre-orientations and the like (pose --> translation & rotation).
Daniel
jukka.alander
Country: Finland
yankoch wrote:
Tue Oct 08, 2019 11:02 pm
No need to convert.
Please let me know.
Thanks, this is just what I was looking for - simple GUI program that anyone can use. :)
Return to “Tips & Advice”
