Actual terrain model from Faro Scene to Autodesk Revit
Post any education related material or training courses that are available to assist with getting users trained in laser scanning.
tkister
Full Name: Tina
Company Position Title: Product Publication Designer
Skype Name: Tina Kister
Re: Actual terrain model from Faro Scene to Autodesk Revit
Post by tkister »
Very funny! ("easy... registry hacking")
blazaj
Full Name: Jiri Blazek
Country: Czech Republic
Post by blazaj »
$480 for a filter plugin seems too much for me as well, but I would prefer the other way around, modelling software handling 1.5mm homogenized pointclouds from Scene.
I like the way Scene renders dense pointclouds which makes it much more legible when exploring details, moving close to walls etc. than pointclouds unified to 5 or 10 mm.
Odesláno z mého Nexus 7 pomocí Tapatalk
kiloweb
Full Name: Philip Lorenzo
Company Details: www.Rithm.io
Company Position Title: Software Developer and Consultant
Skype Name: philipglorenzo
Post by kiloweb »
I'm working on a simple SCENE plugin that will basically allow you to create a quick topographic map, then export directly to AutoCAD/Civil3D (at the correct elevations). It also exports out a spatially sampled point cloud, based on the spacing you want (without any of the hacking), which looks like it might do pretty much what you outlined here.
Does anything think this might be useful? Let me know and I can send you a prototype.
www.Rithm.io | 3D Laser Scanning Plugins | Simplify, Automate, Visualize
blazaj
Post by blazaj »
interesting idea, do you need to clean the pointcloud first or does it include ground point filter?
Oxbow
Full Name: Eric Bergholz
Company Position Title: CEO
Skype Name: eboxbow
Post by Oxbow »
Hi Zolton
you can also check mesh export from pointcab software for FARO laserscanner data.
Look to the manual..
http://www.pointcab-software.com/en/tut ... /#tab-id-4
You can save it as dwg or dxf. Didn`t know, if you can import this to Revit.
regards.. ..Eric
WWilford
Full Name: Warren Wilford
Company Position Title: owner
Been thanked: 4 times
Post by WWilford »
Hello Philip,
I think this would be very helpful. I would be interested in seeing how it works.
Warren
zoltan
Full Name: Zoltan Ferenczy
Company Details: ClearEdge3D
Company Position Title: Industry Strategist
Post by zoltan »
kiloweb wrote:Does anything think this might be useful? Let me know and I can send you a prototype.
YES! This would be very useful to me. Right now I am working with a customer and we are scanning retention ponds to compare them to the proposed grading plans and calculating volumes and areas using Civil3D. The customer needs a solution for this but does not have Civil3d.
I would be happy to beta test this for you.
Has thanked: 45 times
Been thanked: 34 times
Post by Matt Young »
I had a demo from some guys using 'Clearedge 3D buildings' recently. while I am still not convinced about wall extraction, the topo surface extraction was one of the best things I have seen. It's not advertised as one of the main features but it should be, or maybe it should be a standalone module. The math is quite straight forward really I guess, take the lowest points in a grid across the data set and mesh them, simple ;)
Return to “Training Workshops & Online Tutorials”
