How To build A Simple 3D Laser Scanner
Post any education related material or training courses that are available to assist with getting users trained in laser scanning.
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Post by Phil Marsh » Thu Sep 06, 2007 9:17 pm
Introduction.
Create your own super hi-tech 3-D laser scanner. Using just a laser pointer, wine glass, rotating platform, and a digital video camera, you can make accurate 3-D models of an object or person.
Step 1 - Position Camera, Laser, and Cylindrical Lens.
Align the laser so that its beam passes through the cylindrical lens, creating a vertical line rather than a point, and projects onto your target. Initially, the lens was the stem of a wine glass, but in the picture a cylindrical piece of acrylic is used. Position the video camera at a small angle (~15 degrees) from the laser.
Step 2 - Position Target On Rotating Platform.
Create a platform which rotates at a constant angular velocity. Record players, for example, are perfect for small objects. Position your target at the center of rotation. And make sure your target closes there eyes!
Step 3 - Lights, Camera, Action !
Turn off the lights. To make the image processing easier, it's very helpful to get the room as dark as possible so that only the reflected laser light is visible. Rotate your target at a constant angular velocity. Record the video. Notice how protruding features displace the laser line.
Step 4 - Process The Video !
Convert the video to an AVI. Use an edge detection algorithm to find the location of the laser line. Reconstruct your 3-D model.
Conclusion
Try the software yourself. And Email me for a MATLAB script, which was used to generate the image.
http://www.mathworks.com/products/matlab/tryit.html
bugmenot
Full Name: Bugmenot
Company Details: none
Company Position Title: none
Re: How To build A Simple 3D Laser Scanner
Post by bugmenot » Mon Apr 12, 2010 5:01 am
I don't know if it's only myself (somewhat schizo browsing rig), or if the linked images are truly missing. When I loaded the images in the tutorial manually, they give return a 404.
Phil Marsh
Post by Phil Marsh » Mon Apr 12, 2010 11:54 am
Return to “Training Workshops & Online Tutorials”
