Scan Plan - Laser scan planner
Anyone wishing to advertise their company capabilities, individual abilities or looking for freelance work then feel free to here.
Mrk
Full Name: Mark Lane
Company Details: LTS Lockley
Company Position Title: 3D Laser Scanning and BIM
Has thanked: 7 times
Been thanked: 15 times
Post by Mrk »
Hi folks,
I gained some pretty great feedback from the community here at LSF with regard to my bespoke target generator, TLS Targets. So I'm back to seek further perspectives for my new tool: Scan Plan, a tool for planning & estimating terrestrial laser scanning. Much like TLS Targets it's a pretty simple app containing the following fearures:
  • Load PDF plan
  • Place low, medium, & high density setups
  • Specify setup times
  • Tally total setups & scan times
  • Export PDF scan plan
Proposed new features:
  • Load image/take photo
  • Load saved Scan Plan
  • Improved UI for mobile
  • Nominate target positions
  • Nominate approx. benchmark positions
  • Multipage PDF support
  • Scale-up & export part plan
Appreciate any feedback/criticism offered :D
Scott.Warren
Full Name: Scott Warren
Company Details: WSP USA
Has thanked: 17 times
Been thanked: 46 times
Re: Scan Plan - Laser scan planner
Post by Scott.Warren »
Love this, keep up the good work.
Now something that might help us Field360 app users is an Android/iOS version so we can do our target sketches on the tablet in the field! for whatever stupid reason, Leica built in the functionality to geotag things in the scans using the tablet, just not targets, because, reasons?
James Hall
Full Name: James E Hall
Company Details: Dewberry Engineering Inc
Has thanked: 4 times
Been thanked: 29 times
Post by James Hall »
Hello Mark,
Inside and out side scan layouts are a bit different for me. Having a max target distance to keep track of.
The targets with the scanner I'm using need to be with in 50m of the scanner, So my scan setups scan only be 100m away from each other.
It also helps to have the setups and targets labeled. Having function to track the traverse loops would be nice as well.
sreed
Full Name: Scott Reed
Skype Name: sabotva
Has thanked: 8 times
Been thanked: 9 times
Post by sreed »
Great app! Thanks for sharing.
I'm curious what settings or what targets accommodate 50m ranging! Maybe it's the hardware? On the faro s70 we can get green on 27m (30m at 3x sampling) for our 230mm spheres but generally try to stay under ~22m.
Mrk
Post by Mrk »
Appreciate the feedback gents. I'll work towards adding these requests...links and labels shouldn't be a problem, but I'll have to write a complex function to calc the target distances based on PDF sheet size & plan scale.
I've deployed an update with the following upgrades:
  • Load image (PNG & JPG)
  • Load saved template txt file
  • Improved mobile UX
James Hall
sreed wrote: Sat Sep 07, 2019 4:19 am Great app! Thanks for sharing.
The old Leica "6 INCH TURN AND TILT HDS TARGETS" Max range is about 150 feet. (Rescaning until you can see the center) You can see the blue dot at the center of the target in a target scan 100% of the time at 75 feet. If the laser misses the reflective dot at the center of the scan you have to add the target manually.
MajorDomo
Full Name: Major Domo
Company Details: VeritasVfx
Company Position Title: ceo
Country: Portugal
Been thanked: 28 times
Post by MajorDomo »
Quite slow and not ideal, but i got the P40 to detect targets 90m away.
On some jobs you just gotta do it...
Has thanked: 171 times
Been thanked: 42 times
Post by gsisman »
Scott.Warren wrote: Fri Sep 06, 2019 2:39 pm Love this, keep up the good work.
Scott,
I used the picture capability on the iPAD pro in conjunction with the Photo Editing system app of the iPAD.
What kind of sketch did you mean? Can't you geotag your targets within the scanner view window- take photos, edit them & draw on with notes if need be & attach the photos as the Geotag (gives you a choice of taking photo or attaching an image from the iPAD library)
Return to “Advertising”
