3D Laser Scanning Project Surveyor Needed! (Indianapolis)
Is your company expanding or simply on the look out for experinced laser scanner users then you can try to recruit staff here.
GeoSearch
Full Name: Jessica
Company Details: GeoSearch Inc
Company Position Title: Sr. Recruiter VP of Sales
Post by GeoSearch »
If you are interested, contact [email protected] or visit www.geosearch.com to apply.
This position will require completing all aspects of 3D laser scanning and surveying from field data collection to developing point cloud deliverables. Duties will include processing point clouds collected by 3D laser scanning or similar systems and convert into 3D point cloud models using FARO Scene, Autodesk ReCap and AutoCAD, or similar 3D design software programs. Projects will consist of building interiors & exteriors, factories, mechanical rooms, and similar infrastructure to develop existing conditions 3D deliverables. Work collaboratively with Project Management to ensure client deliverables meet specifications and are completed to the highest level of detail and accuracy according to company defined quality standards. This position is based in Carmel, Indiana.
Responsibilities for this position include but are not limited to:
• Working independently or as part of a team visiting client locations capturing existing project/building conditions using terrestrial 3D laser scanners.
• Post process field collected scan data and register with FARO Scene, Cyclone, Autodesk ReCap or similar point cloud processing software tools.
• Verify point cloud alignment using survey dimensional control techniques.
• Work without direct day-to-day supervision and make technical and supervisory decisions for projects assigned within specified limits of authority.
Minimum Requirements:
• Minimum 1-year experience as a Survey Technician or 3D Scan Technician having both field and office experience.
• Experience with operation of FARO, Leica, or similar 3D scanners is a plus and will be given priority consideration.
• Experienced converting point clouds into CAD & BIM model deliverables will be given the highest consideration.
• Skilled in the use of GPS devices, data collectors and/or Total Station.
• Must demonstrate knowledge of the principles, techniques and practices of land surveying.
• Must be available to work Monday through Friday with occasional evenings & weekend work and available to travel to client sites when needed.
• Must have a valid driver’s license.
Return to “Recruitment”
