TruView Won't Load
- I have made 100> posts
- 15
- Full Name: Dylan LeFebvre
- Company Details: Allnorth
- Company Position Title: Reality Capture Group Lead
- Been thanked: 3 times
TruView Won't Load
Hey all,
Not sure if anyone has seen thise before, but my TruView site map load fine in Explorer but once I select a scan to go into the scene doesnt seem to load completely (see image). Any ideas?
thanks
thanks
- Mike Annear
- Full Name: Mike Annear
- Has thanked: 122 times
- Been thanked: 196 times
Re: TruView Won't Load
You will probably also see that the menus on the left hand side are all screwed up,
This is pretty common unfortunately.
Turn everything off, restart, contact your Leica Dealer
Mike
Mike
- Phil Marsh
- Administrator
- Full Name: Phil Marsh
- Skype Name: phil.h.marsh
- Has thanked: 117 times
- Been thanked: 36 times
Make sure the managed addon for Leica are all running in IE. Also try changing the security settings as this always works for me.
- Matt Young
- Honorary Member
- Full Name: Matt Young
- Has thanked: 45 times
- Been thanked: 40 times
You will need to install the latest version of TruView - that looks like the old one.
When installed, just check that the add-on is enabled.
- Full Name: Micael Samuelsson
- Company Details: Adecco
- Company Position Title: Support
- Country: Sverige
- 15
I honestly can't remember specifically what i did to get it working consistently. I think I was in "internet options" in internet explorer, "Programs" tab, then "Manage add-ons". I think I had two versions of TruView in there so I disabled on of them / enabled the other...something along those lines. Sorry it was a while back and I haven't had an issue since.
- freddie@asbuilt
- I have made 30-40 posts
- Full Name: Freddie Nodalo
- Company Details: AsBuilt LTD
- Company Position Title: HDS Technical Support
- Country: New Zealand
The first thing to check is making sure that the plugin is enabled in Internet Explorer:
- Select Tools > Manage Add-ons
- You should see LeicaGeosystems.Truview.BHOIEContextMenu and it should show as enabled.
Also, some companies have group policy settings enforced, so it may be necessary to check the following box:
- Select Tools > Internet Options > Advanced tab, then check Enable third-party browser
extensions
- Select Tools > Internet Options > Advanced tab, Security then check Allow active content to run in files on My Computer
extensions
- Full Name: Joe Mezzanini
- Company Details: Herkimer College
- Company Position Title: tech
freddie@asbuilt wrote: ↑Thu Jan 29, 2015 12:10 am The first thing to check is making sure that the plugin is enabled in Internet Explorer:
extensions
That worked for us. Thank You
(If you don't see the TOOLS menu, press the ALT key)
Appreciate everyone's time
