TruView Won't Load
3DUserNet, Pointbox, Potree, TrueView, WebShareCloud, Etc.
dlefebvre
I have made 80-90 posts
Full Name: Dylan LeFebvre
Company Details: Allnorth
Company Position Title: Technologist Designer
TruView Won't Load
Post by dlefebvre »
Hey all,
Not sure if anyone has seen thise before, but my TruView site map load fine in Explorer but once I select a scan to go into the scene doesnt seem to load completely (see image). Any ideas?
thanks
mike annear
Full Name: Mike Annear
Company Details: Mike Annear
Has thanked: 4 times
Been thanked: 19 times
Re: TruView Won't Load
Post by mike annear »
You will probably also see that the menus on the left hand side are all screwed up,
This is pretty common unfortunately.
Turn everything off, restart, contact your Leica Dealer :)
Mike
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Has thanked: 26 times
Been thanked: 11 times
Post by Phil Marsh »
Make sure the managed addon for Leica are all running in IE. Also try changing the security settings as this always works for me.
LASER SCANNING FORUM
Has thanked: 45 times
Been thanked: 35 times
Post by Matt Young »
You will need to install the latest version of TruView - that looks like the old one.
When installed, just check that the add-on is enabled.
dlefebvre
Post by dlefebvre »
I got it going. Thanks everyone.
mmicaels
Full Name: Micael Samuelsson
Company Details: Adecco
Company Position Title: Support
Country: Sverige
Post by mmicaels »
what did you do to get it running? I am having the same issue.
dlefebvre
Post by dlefebvre »
I honestly can't remember specifically what i did to get it working consistently. I think I was in "internet options" in internet explorer, "Programs" tab, then "Manage add-ons". I think I had two versions of TruView in there so I disabled on of them / enabled the other...something along those lines. Sorry it was a while back and I haven't had an issue since.
Full Name: Freddie Nodalo
Company Details: AsBuilt LTD
Company Position Title: HDS Technical Support
Country: New Zealand
Post by [email protected] »
The first thing to check is making sure that the plugin is enabled in Internet Explorer:
- Select Tools > Manage Add-ons
- You should see LeicaGeosystems.Truview.BHOIEContextMenu and it should show as enabled.
Also, some companies have group policy settings enforced, so it may be necessary to check the following box:
- Select Tools > Internet Options > Advanced tab, then check Enable third-party browser
extensions
- Select Tools > Internet Options > Advanced tab, Security then check Allow active content to run in files on My Computer
theMezz
Full Name: Joe Mezzanini
Company Details: Herkimer College
Company Position Title: tech
Post by theMezz »
[email protected] wrote:
Thu Jan 29, 2015 12:10 am
extensions
That worked for us. Thank You
(If you don't see the TOOLS menu, press the ALT key)
Appreciate everyone's time
Return to “Web Based Software”
