Main Features
There are new workflows to create or enhance WebShare Cloud projects.
- Adding a high quality point cloud to an existing project for astonishing 3D visualizations in the browser as an addition to the panoramic images.
- Creating projects from Freestyle data, sections of a project or any other point cloud data. This ends the necessity to create virtual scans to visualize point cloud data from sources other than laser scanners.
- Replacing an existing point cloud or adding additional point clouds to a project. Use this to bring in fresh data at any time: Form a time-series of several point clouds to let your users track changes on the project site. Or replace a point cloud with an updated version after applying more cleanup operations.
Check out a small demo project with such an improved point cloud!
Attached, you can see a typical example of the quality improvements thanks to SCENE’s color balancing features when creating a project point cloud that is then used by WebShare Cloud this way.
Other new Features
- Project management tasks have been restructured for a better user experience.
- A project can now have multiple point clouds.
- In the overview map scan clusters are colored by age or height depending on the setting.
- In the overview map cluster behavior has been changed to show more individual scan markers.
- The coordinates of the coordinate picker can be copied to the computer’s clipboard.
- The coordinates in the properties of an object can be copied to the computer’s clipboard.
- A custom coordinate system can be defined for each project.
