Potree - WebGL pointcloud viewer
3DUserNet, Pointbox, Potree, TrueView, WebShareCloud, Etc.
fabrizio.cavallo
Full Name: Fabrizio Cavallo
Company Details: FABRIMAR S.r.l
Re: Potree - WebGL pointcloud viewer
Post by fabrizio.cavallo »
Does anyone have experience with the new Riegl RiAlity?
Excuse me if the question may seem off-topic.
Fabrizio Cavallo - CEO
Fabrimar S.r.l.
Via Pitagora n° 24 – 74123 Taranto – Tel. 099.4526930 – Fax 099.22098308
Via Festa del Perdono n° 1 – 20122 Milano – Tel. 02.87156430 – Fax 02.93667828
Italy
mschuetz
Full Name: Markus Schuetz
Company Details: potree.org
Company Position Title: developer
Country: Austria
Post by mschuetz »
I've put the potree source on github now. Documentation and PotreeConverter sourcecode will be available on github within the next few days.
https://github.com/potree/potree
Phil Marsh wrote:Can you write some simple instructions on how to get data into this format?
It would be great to have an GUI to simply convert the data.
The latest release comes with 2 binaries:
* converter/xyzrgb2bin.exe
Converts ascii data to the binary format that PotreeConverter.exe expects.
The ascii file must contain 3 floats for xyz coordinates and 3 integers for color values.
For example:
Code: Select all
1.2312 4.311 5.12312 100 125 210
1.2312 4.311 5.12312 123 124 125
* converter/PotreeConverter.exe
Converts the output of the xyzrgb2bin to the potree format.
* converter/usage.txt explains how to call these executables.
A GUI is not planned, yet, but I'll look into it once the converter has a few more features such as more input formats.
Oatfedgoat
Full Name: Matthew McCarter
Company Details: Costain
Country: England
Has thanked: 5 times
Post by Oatfedgoat »
That's excellent. Much appreciated.... but - Would it be possible to also make a file that enables those of us that dont have RGB with our scans to convert it by releasing something for XYZi please?
mschuetz
Country: Austria
Post by mschuetz »
Oatfedgoat wrote:That's excellent. Much appreciated.... but - Would it be possible to also make a file that enables those of us that dont have RGB with our scans to convert it by releasing something for XYZi please?
If you know C++, you can already get the source and adapt it to your needs: http://potree.org/downloads/PotreeConverter_source.zip
But I'll try to upload a version that handles XYZi in the next few days, maybe even later today.
blazaj
Full Name: Jiri Blazek
Country: Czech Republic
Post by blazaj »
Matt,
you can also use cloudcompare to convert intenyity to RGB values.
Odesláno z mého Nexus 7 pomocí Tapatalk
mschuetz
Country: Austria
Post by mschuetz »
Here is an executable to convert from xyzi to the binary format that is required by the PotreeConverter. You'll still have to the PotreeConverter afterwards.
http://potree.org/downloads/xyzi2bin.exe
Your XYZi file must look like this:
Code: Select all
-0.0378297 0.12794 0.00447467 0.850855
-0.0447794 0.128887 0.00190497 0.900159
-0.0680095 0.151244 0.0371953 0.398443
usage:
Code: Select all
./xyzi2bin <input> <output> <intensityRange>
./xyzi2bin C:\pointcloud.xyz C:\pointcloud.bin 1
Where intensity range indicates the largest possible intensity. This is used to normalize color data.
Support for more formats will follow in the future.
mschuetz
Country: Austria
Post by mschuetz »
Hi, there have been some updates:
I rewrote everything based on three.js. This means, you can now render everything three.js can as well. Skyboxes, meshes and lines, for example.
The converter can now convert *.las, *.ply and *.xyz files (with certain restrictions), see PotreeConverter
It also works on my mobile phone (firefox/android) to some extent.
Click on animage below to open a demo page:
Distance measure tool example:
Skatepark:
Multiple instances of one pointcloud:
3DForensics
Full Name: Eugene Liscio
Skype Name: eliscio
Post by 3DForensics »
Hi Markus,
Works great for these size of point clouds.
Eugene
gwhitch
Full Name: Gary Whitcher
Company Details: Blue Sky Evolution
Post by gwhitch »
I want to be able to rotate an object after it gets loaded into the cloud.
Can an object be rotated along each axis? I have tried to use the same approach as in moving them, (movedist is a local variable)
object_loaded.position.set(parseFloat(object_loaded.position.x) - parseFloat(movedist), parseFloat(object_loaded.position.y), parseFloat(object_loaded.position.z));
using:
object_loaded.rotation.set(parseFloat(object_loaded.rotation.x) - parseFloat(dtr(movedist)), parseFloat(object_loaded.rotation.y), parseFloat(object_loaded.rotation.z));
I don't get an error but nothing happens. Am I missing something?
Return to “Web Based Software”
