How do you use laser scanning data for topographic survey?
- Koalar
- Full Name: Guangdong Qiao
- Company Details: SpatialSolutioner
- Country: China
- Skype Name: koalar2012
Let's discuss about this topic: how to use point cloud data for topographic surveying.
Though the laser scanning data is a kind of big data that we can get lots of benefit from this kind of detailed information, as we can visualize the scene in digital format or we can extract anything we need.
But to transfer 3D information into 2D is still needed during this period. Moreover, different country maybe with different standard for topographic results.
How are you dealing with this kind of application in your country?
What's the software you use for the conventional topographic survey? How about now?
Regards
Koalar Q
Regards
Koalar Q
- ChrisJPalmer
- I have made 100> posts
- Full Name: Chris Palmer
- Company Details: FARO Technologies
- Company Position Title: 3D Documentation Engineer
Re: How do you use laser scanning data for topographic surve
I have been helping out a few of our customers recently using the following plug-in for FARO Scene, which gives pretty awesome results directly into CAD or to help produce DTMs or topo-surfaces in Revit:
http://www.faro.com/faro-3d-app-center/ ... eyor-rithm
If you are not a FARO user (why not !) or just happen to take your data straight into AutoCAD, there are some great new 3D snap features in 2015, whilst there is also a really cool plugin for Civil 3D for produce contour maps and DTM
- Koalar
- Country: China
ChrisJPalmer wrote:I have been helping out a few of our customers recently using the following plug-in for FARO Scene, which gives pretty awesome results directly into CAD or to help produce DTMs or topo-surfaces in Revit:
Thanks for your reply. I have read the manual of app for scene, that's useful. I wonder is there any standard for topo survey in your country? Like surveyors need to use a certain kind of symbol library to drawing the 2D map in CAD software.
If point, line, polygon are the basic elements for topo drawing, I will use AutoCAD or Civil 3D with recap, but in China we need to draw maps with certain symbols, otherwise the topo maps could not be used officially.
- Matt Young
- Honorary Member
- Full Name: Matt Young
- Has thanked: 45 times
- Been thanked: 40 times
We have some in-house routines that we have been running with AutoCAD for a long time. When laser canning came along and we started using Cloudworx for AutoCAD we simply altered our workflow slightly. We still use the same routines for placing symbols, text and other elements but now have the ability to do the survey on the desktop in a much more visual way than before.
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
Because this seems interesting a follow-up.
I'm using Scene for registering my pointclouds; Pointsense, Virtusurv and Pointcab for data extraction but specific surveyor needs ask me to look forward.
Is anybody using either Rithm Surveyor, DTMSoftware or Carlson Pointcloud,...? Rithm seems interesting because of the integration with scene, I use carlson civil suite for my engineering stuff so maybe this is more functional?
Greetings,
Lieven
Greetings,
Lieven
- Full Name: Fabien
- Company Details: Amec Foster Wheeler
- Company Position Title: Geomatics Project Manager
That's most of our work, civil/survey. I use a combination of Cyclone, cloudworx, Bentley Descartes, Microstation.
- MarkL
- Full Name: Mark Lupton
- Company Details: Wolverton
- Company Position Title: LASER Scanning
- Skype Name: [email protected]
I've done a few in AutoCAD, mainly using Cloudworx or importing ReCap files of clouds segmented in Cyclone. We have access to a cheaper scanner, which we are integrating with the field crews so they can keep one with them and use it when they deem necessary. It's still a bit laborious to get curbing right, but once that's out of the way it's quite easy to get a good dtm. Other items such as power poles, manholes and valves can be added by just creating a cogo point with the correct code. We are developing custom routines to deal with linework from the scans, but it all takes time.
- Full Name: Fabien
[quote="MarkL"]...It's still a bit laborious to get curbing right, but once that's out of the way it's quite easy to get a good dtm..." /quote]
Curbing is always the issue. Even with Cyclone alignment tool, it is still hard to get the back of the curb.
- Dedken
- Full Name: Kenneth Bazley
- Company Details: Sir Robert McAlpine
- Company Position Title: Senior Geospatial Engineer for HDS
Lieven, did you know that if you have a Pointsense license you can use the Draw-To-CAD free app in Scene? It's a very simple tool, but incredibly quick for outputting points to CAD. At one point I trialled Rithm Surveyor and Draw-To-CAD on the same project and I found that despite the options Rithm Surveyor has (layering, for example) overall I found it much easier to use Draw-To-CAD and to layer my linework in ACAD.landmeterbeuckx wrote:Because this seems interesting a follow-up.
Greetings,
Lieven
In terms of software for topos LSS is my software of choice - it now has a really powerful engine for utilising pointclouds.
All views are my own and are not representative of my employer, The King, God or anyone else for that matter.
- landmeterbeuckx
- Country: Belgium
Hi Kenneth,Dedken wrote:Lieven, did you know that if you have a Pointsense license you can use the Draw-To-CAD free app in Scene? It's a very simple tool, but incredibly quick for outputting points to CAD. At one point I trialled Rithm Surveyor and Draw-To-CAD on the same project and I found that despite the options Rithm Surveyor has (layering, for example) overall I found it much easier to use Draw-To-CAD and to layer my linework in ACAD.landmeterbeuckx wrote:Because this seems interesting a follow-up.
Greetings,
Lieven
I've used the draw to cad plugin and find it indeed a practical solution. I haven't tested the Rithm Surveyor app but it seems this is a combination between virtusurv (macro driven) and the Draw to cad.
I love Virtusurv but find the separate files very heavy to work with.
I also want to work with data without having to transfer to rcp, e57, virtusurv,etc... Just load my cloud and start drawing as i would measure in the field with my total station.
I've asked for a trail license for LSS but they answered that they are developing a full release and do not give (temporalily) trail licenses anymore. I do want to test it.
