AutoCad - Pointcloud
AutoCad, MicroStation, ZWCAD, ARES, GstarCAD, 4M, IntelliCAD Etc.
MalteHC
Full Name: Malte Holm
Company Details: TLS
Country: Norway
Post by MalteHC »
Hi All
I dont know, why this has to be so hard in all of Autodesk productsk, but i want to attach a georefrenced pointcloud in autocad.
I cant really seem to get it in. It want me to specify a point and i cant really seem to find a way to attach it to its real coordinates.
Any suggestions?
Fairos
Full Name: David ison
Company Details: Castle Surveys
Country: England
Re: AutoCad - Pointcloud
Post by Fairos »
What have you used to register the pointcloud data?
Have you got cloudworx/cyclone?
MalteHC
Country: Norway
Post by MalteHC »
It is in a registered Recap file.
No, i have not got cloudworks.
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 125 times
Been thanked: 30 times
Post by gsisman »
MalteHC wrote:
Fri Jan 25, 2019 11:55 am
A register recap file. Is it registered to CTRL points (Text File import) in the coordinates system you want it in?
If so remember that Recap DB is in Meters. Set up your civil 3D DWG file or ACAD file in the coordinate system that you used for point cloud (and make sure the units are in Meters. Put the insert units in meters (UNITS command).
You should be able to then inport it using the Insert/Attach Point Cloud\Choose RCP file options (Image)
MalteHC
Country: Norway
Post by MalteHC »
gsisman wrote:
Fri Jan 25, 2019 12:58 pm
But then you do, you have to insert a project base point, which makes it local. im not able to use the georefrenced system, that my recap file contains.
caddrafting2013
Full Name: Adam
Company Details: ADB3D Pty Ltd
Company Position Title: Director - Revit and Laser scanning
Been thanked: 5 times
Post by caddrafting2013 »
Rcs file straight into Autocad - Make sure you uncheck box specify on screen.
Been doing it for years and then bring back DWG into Revit all holds same geo reference location.
MarkL
Full Name: Mark Lupton
Company Details: Wolverton
Company Position Title: LASER Scanning
Skype Name: [email protected]
Post by MarkL »
Inserting at 0,0,0 means it doesn’t add any numbers to your registered coordinates. Uncheck “specify on screen” from the insert box and don’t scale or rotate. Hopefully your import units were correct in ReCap, if not you can either redo it, or scale about 0,0, depending on who’s using it after you.
Return to “CAD Software”
