Faro .fls into Aveva PDMS
AutoCad, MicroStation, ZWCAD, ARES, GstarCAD, 4M, IntelliCAD Etc.
boxel0
I have made 90-100 posts
Full Name: Lewis Boxer
Company Details: Advanced 3D Laser Solutions Ltd
Post by boxel0 »
Hello all,
We have done some basic scanning for a company, who are now wanting to import the detail into PDMS, we use mostly Autodesk software and I have no idea how to get scan files into PDMS.
Does it need to be converted, by specialist Aveva software like recap?
Or can it import .fls directly?
or can i convert it into something from FARO Scene, which would allow them to import them?
Please help
Lewis Boxer
Technical Director
e: [email protected]
w: www.lasersurveying.com
richard_m
Full Name: Richard Merrin
Company Details: Fugro
Country: Netherlands
Re: Faro .fls into Aveva PDMS
Post by richard_m »
I'm not a PDMS user but I assume it will not read laser data in proprietry formats such as .fls
For our clients we usually build an LFM Server database (LFM is also Aveva) which generates a .lfd format that all other Aveva software works with.
Maybe if you export your entire registration in a generic format (e57 or las(z)) then PDMS will import it but I've never heard of it.
Richard.
danielgadowski
Full Name: Daniel Gadowski
Post by danielgadowski »
You really need to ask your client what is he using to take he clouds into PDMS. It can be either LFM or Cloudworx. If it is LFM then you will need to follow what Richard has mentioned which will most likely mean purchasing a new software package or getting someone else to do it for you. Alternatively they might have LFM importer in which case you just supply them with PTX files for each scan.
There are some more clued up people here that know the route extensively so they may be able to help.
Good luck
Daniel
Graham
Full Name: GrahamM
Company Details: AVEVA
Post by Graham »
AVEVA PDMS accesses laser data using Laser Model Interface http://www.aveva.com/Products_and_Servi ... ogies.aspx. Your client will need a laser model/point cloud in one of the supported system, LFM, Leica, Riegl, Quantapoint and Trimble.
The FLS files can be read directly into LFM Server to generate a laser model from, I believe Leica Cyclone can also read FLS files.
Most engineering companies have very little or no experience of laser scanning, they generally have no idea how the survey is captured and a laser model is generated. As a result the generation of the laser model from the laser scans (FLS files) is generally considered a back office action typically undertaken by a service provider i.e. yourself.
Before you do supply the data, do check that it is in the coordinate space they expect i.e. it is in plant space.
If the client is using AVEVA Everything3D they will be able to access BubbleViews(tm) within the Model environment and laser data within the Draw product.
http://www.aveva.com/en/Products_and_Se ... A_E3D.aspx
boxel0
Post by boxel0 »
Thank you guys for all your help
Lewis Boxer
Technical Director
Sara Rahimi
Full Name: Sarah Rahimi
Company Details: Laser scanning
Company Position Title: Self Company
Country: Iran
Post by Sara Rahimi »
hello every body.could you help me how can I import point cloud to pdms?I converted point cloud to lfd by lfm server
Sara Rahimi
Country: Iran
hi I have lfd data base but i cant import to pdms .could you help me?
Graham
Full Name: GrahamM
Post by Graham »
Sara,
Welcome to the forum. To access the laser data within PDMS you will need to be using PDMS 11.6SP2 or the PDMS 12 series. This will allow access to the LMI Interface, this allows PDMS to communicate with via the PDMS CADLink to LFM Server and render, clash and interact with the point cloud in PDMS.
Product page
https://www.aveva.com/en/Solutions/Prod ... FM_Server/
I can also recommned the AVEVA World Forum
https://www.avevaworldforum.com/
Return to “CAD Software”
