Reverse engineering software
AutoCad, MicroStation, ZWCAD, ARES, GstarCAD, 4M, IntelliCAD Etc.
drpadella
Full Name: Andrea
Company Details: NTSB
Company Position Title: Senior Technician
Country: Italia
Post by drpadella »
I'm new to this forum.
As shipyard we recently purchased a faro focus s70. We mainly want to use the scanner to create CAD model of ships that
we have to modify (enlarge, extend). FARO scene as software in not so efficent to make a mesh model from point cloud, and
Rhinoceros for reverse engineering is quite tricky.
So we are looking for a software that can make both (3d meshing and reverse engineering).
Geomegic design is an overkill for the shapes we are working with.
Is there a budget software that will do the trick?
Andrea
GCFdesign
Full Name: Gary Fellows
Company Details: GCF Design Limited
Has thanked: 27 times
Been thanked: 13 times
Re: Reverse engineering software
Post by GCFdesign »
Gary Fellows
Director
GCF Design Limited
https://gcfdesign.wixsite.com/gcfdesign
drpadella
Full Name: Andrea
Country: Italia
Post by drpadella »
If I'm not wrong CloudCompare is a good solution for meshing a point cloud but can't create CAD surfaces.
GCFdesign
Post by GCFdesign »
Yes it can.
Gary Fellows
Director
GCF Design Limited
GCFdesign
Post by GCFdesign »
You extract your draughting from the mesh.
Gary Fellows
Director
GCF Design Limited
Mike Annear
Full Name: Mike Annear
Company Details: Mike Annear
Has thanked: 12 times
Been thanked: 45 times
Post by Mike Annear »
Hi Andrea,
I agree with Gary, CloudCompare is a good solution for meshing, it takes a bit of tweaking but it works well once you have good starting numbers.
The trick is to use the Scalar field to trim the mesh after the Poisson plugin has finished.
Most of the boat builders that I work for use Rhino 3D, it can be tricky, but I find it works very well with pointclouds.
Mike Annear.
Mike Annear
www.mikeannear.com
QLD, Australia.
drpadella
Full Name: Andrea
Country: Italia
Post by drpadella »
Thanks both for the reply.
I'm now looking into mesh2surface plug-in for Rhino, looks pretty good for the kind of shapes i'm working with.
Any experience with that plug-in?
Mike Annear
Hi Andrea,
I looked at it some time ago, but it seems to be aimed more at industrial metrology, not larger scale objects that I usually deal with.
Plus I try to avoid working with meshes, I prefer working from the original pointclouds.
I tend to model the old fashioned way, I just extract cross sections manually, then loft those together to create complex surfaces.
Rhino surfacing is based on curve networks, you just have to work out which curves you need from the point cloud.
I have heard T-Splines is the way to go, but Autodesk bought it for "Fusion 360" and it is no longer available for Rhino 3D. Apparently McNeel (Rhino) are working on their own version.
It is a similar scenario to when Bentley bought "Point Tools" and killed it for Rhino 3D users, thankfully Veesus stepped up with a very similar product in "Arena 4D" which is brilliant to use.
EDIT - I have just had a look at "Xirus for Rhino", it looks very similar to T-Spines and pretty reasonably priced.
Mike.
www.mikeannear.com
Mike Annear
www.mikeannear.com
QLD, Australia.
Return to “CAD Software”
