Joon
Full Name: Sung Joon Ahn
Company Details: CurvSurf
Country: Republic of Korea
Been thanked: 4 times
Post by Joon »
Solar Power Generator - Google ARCore / Apple ARKit
Extracting roof plane and tank cylinder from ARCore / ARKit point cloud.
Tools used:
- Samsung Galaxy Note 9
- Google ARCore 1.7
- OpenGL ES 3.1
- Apple iPhone XS Max
- Apple ARKit 2.0
- Apple Metal API
- CurvSurf FindSurface.
ARCore shows a solid motion tracking, but
ARKit is losing the motion tracking at distance.
The reason: ARKit ignores distant feature points.
youtu.be/FMytXWXQ6wg
Solar Power Generator - Apple ARKit
youtu.be/4cp7Qg6WCFw
Joon
Post by Joon »
A comparison of motion tracking between HoloLens, ARKit and ARCore
  • Microsoft HoloLens: solid motion tracking except latency
  • Apple ARKit: lost motion tracking at distance
  • Google ARCore: solid motion tracking.
Tools used:
- Microsoft HoloLens
- Microsoft DirectX
- Apple ARKit 2.0
- Apple Metal API
- Google ARCore 1.9
- OpenGL ES 3.1
Sculptor:
Lee JaeHyo (이재효, 0121-1110=1)
http://www.leeart.name
Lee JaeHyo Gallery Column Cylinder - HoloLens
youtu.be/dYtPFWy_WxU
Lee JaeHyo Gallery Column Cylinder - ARKit
youtu.be/PkHjW68JMHQ
Lee JaeHyo Gallery Column Cylinder - ARCore
youtu.be/PeRjJOPCTQU
Joon
Post by Joon »
Another comparison of motion tracking between HoloLens, ARKit and ARCore
Sculptor:
Lee JaeHyo Gallery Ball Park - HoloLens
youtu.be/5sEnrZW3yks
Lee JaeHyo Gallery Ball Park - ARKit
youtu.be/QhBtGHmfBOg
Lee JaeHyo Gallery Ball Park - ARCore
youtu.be/MPw__oryLm4
Joon
Post by Joon »
Column Cylinder San Francisco Intl Airport - ARCore
Tools used:
- Samsung Galaxy S8+
- Google ARCore 1.7
- OpenGL ES 3.1
For a large and distant object, the motion tracking of Google ARCore is more stable than that of Apple ARKit.
Extraction of feature points from images (i.e., frames) is:
- based on edges (ARCore) or regions (ARKit), and
- including also far points (ARCore) or only near points (ARKit).
Feature points are saved and utilized globally (ARCore) or locally (ARKit).
Joon
youtu.be/G7KLWjpd4Vc
Joon
Post by Joon »
Augmented Reality Based on Curved Object Surfaces - ARKit
The current AR applications are based on horizontal or vertical planes.
CurvSurf FindSurface extends the playground of AR applications to curved object surfaces, e.g., sloped planes, spheres, cylinders, cones and tori.
Tools used:
- Apple ARKit 2.0
- Apple Metal API
youtu.be/4U4FlavRKa4
Joon
Post by Joon »
Augmented Reality Based on Curved Object Surfaces - ARCore
Current AR applications are based on horizontal or vertical planes.
Tools used:
- Google ARCore 1.7
- OpenGL ES 3.1
youtu.be/p2mkBKEp0_U
Joon
Post by Joon »
Star Wars: The Force Awakens
Augmented Reality:
virtual objects on real objects with occlusion.
#arkit #arcore #measure #pointcloud #augmentedreality #occlusion
37°26'01"N 127°01'10"E
Tools used:
- Apple ARKit 2.0
- Apple Metal API
- Google ARCore 1.7
- OpenGL ES 3.1
youtu.be/hGO2oihrT8I
Joon
Post by Joon »
youtu.be/EqQuSTjVL18
AR Occlusion with Large Dome - ARCore
A virtual satellite is flying around a large real dome as an example of AR applications with occlusion.
Google ARCore provides AR applications with device motion tracking and point cloud.
CurvSurf FindSurface determines the size and position of dome by processing the point cloud.
Tools used:
- Google ARCore 1.9
- OpenGL ES 3.1
With Apple ARKit and iPhone XS Max, a comparable result could not be obtained for the large dome, today June 2019.
The Planetarium of Gwacheon National Science Museum (sciencecenter.go.kr) is located at
37°26'21"N 127°00'19"E.
Joon
Joon
Post by Joon »
youtu.be/TmQRbzeaQiU
youtu.be/_RBaxyIlmPk
Far/Mid Distance Small Parallax - ARCore
Large distances between the AR device and the object (feature) points cause too small parallaxes between frames resulting in the needle-shaped distributions of point cloud.
The needle-shaped (i.e., extruded) distribution of point cloud is mapped (projected, viewed) to the vicinity of an image (feature) point from the viewpoint of AR device.
The deviation of points (i.e., the length of needle) is increasing exponentially to the object distance.
Google ARCore extracts feature points even from the clouds in the sky, while Apple ARKit extracts feature points only from max 10 m distant object surfaces. The far distance feature points are indispensable to the large-scale positioning and orientation.
Tools used:
- Google ARCore 1.9
- OpenGL ES 3.1
Joon
Post by Joon »
#arkit #arcore #hololens #realsense #measure #pointcloud #augmentedreality #SLAM #occlusion
There are a variety of point cloud generators. Mobile, speedy and cheap.
The tsunamis of point cloud are well expected. They should be processed, used and then forgotten. Otherwise, we will be drowning.
Google ARCore: Occlusion Tree Trunk
youtu.be/WK1cFcBloDM
Tools used:
- Google ARCore 1.9
- OpenGL ES 3.1
Apple ARKit: Occlusion Tree Trunk
youtu.be/rGW-FtA6P1Q
Tools used:
- Apple ARKit 2.0
- Apple Metal API
Joon
Return to “Modeling Software”
