Presenting 3D models
stutosney
Full Name: Stuart Tosney
Country: New Zealand
Been thanked: 23 times
Post by stutosney »
Hopefully someone can help me out with this as I have been trying to search for a guide but had no luck. I am trying to put together a marketing presentation to show off the various 3D work we do as a company and I have been trying to get a screenshot of a half scan half model. I have attached a picture below showing the desired result but I cannot find the solution anywhere. I have access to to Navisworld, Recap, Revit, CAD & 3D Reshaper so any help would be much appreciated.
Thanks,
Stuart
Formula1982
Full Name: Stephen Ferrari
Has thanked: 5 times
Been thanked: 6 times
Re: Presenting 3D models
Post by Formula1982 »
I think you're possibly looking for a solution that's way more complicated than is necessary to make the image you're looking for.
Assuming you have the data as RGB coloured, then take a screenshot of the data with colour turned on, then colour turned off and intensity active. Then using photoshop (or something similar) make a blended image which is half one, half the other, with a fade transition in-between.
gilles_3DR
Full Name: Gilles Monnier
Company Details: Hexagon
Been thanked: 7 times
Post by gilles_3DR »
Hi Stuart,
The tip I use in 3dreshaper is described in this video:
youtu.be/_Vk0zNMByPQ
The tip is to use clipping plane but assign a clip to only part of the data you want to show.
Then, use another clipping plan to clip so other 3D data.
Before, rendering, just hide the clip!
stutosney
Post by stutosney »
Excellent, thanks for the responses. I spent many an hour typing random word combinations into Google for a solution! I will give it a go and see what happens.
duncan_jamieson
Full Name: MR DUNCAN JAMIESON
Company Details: LM Surveys
Company Position Title: 3d Documentation Surveyor
Skype Name: [email protected]
Post by duncan_jamieson »
Both Revit & Recap have 'export image' options that might get you slightly better resolution than a screenshot. Then, as mentioned above, you can use a Photoshop like program to blend them. GIMP is a fee-free option. Good luck!
john-newbegin
Full Name: John Newbegin
Company Details: Travis County Sheriff
Company Position Title: Engineering Specialist
Post by john-newbegin »
I think easier might be to have 2 static images one fully rendered 3d, and then one as point cloud with same camera angle/zoom etc for both, then just make a transition between the 2 in any video editing software, just like a normal A/B transition, you could do wipe/fade etc.. any standards video transitions between the two, this has worked out for me nicely before with only having 2 images it makes it look a lot fancier than it really is..
Return to “Modeling Software”
