Quality check of DWG VS. Pointcloud
MalteHC
Full Name: Malte Holm
Company Details: TLS
Country: Norway
Post by MalteHC » Thu Apr 19, 2018 9:38 am
Hi All
I have a drawing department, that draw DWG plans, from pointclouds. The drawings are done in X,Y,Z and my job is to make the quality check. Currently i either check them in MicroStation or Revit, where i make crosssections, to see if the lines is placed correctly in Z and afterwards i control the line in X,Y in a topview.
But this is very timeconsuming, to manually make 1000 crosssections.
Does anyone of you have any experience in this matter and have figured out some smater method for the quality check?
gilles_3Dreshaper
Full Name: Gilles Monnier
Company Details: Technodigit
Re: Quality check of DWG VS. Pointcloud
Post by gilles_3Dreshaper » Thu Apr 19, 2018 9:00 pm
Hi mate,
How about a colormap inspection showing the distance between the point cloud and the drawings?
Would that make sense in your case?
Gilles
3DReshaper Manager
http://www.3dreshaper.com
MalteHC
Country: Norway
Post by MalteHC » Fri Apr 20, 2018 7:50 am
Hi mate,
The DWG is just vector lines and not a surface, how would you control that acccording to a curb, placement of pavement or so? Keep in mind, this has to be done within 1-2mm.
hsnguyen
Full Name: Huynh Si Nguyen
Company Details: VMT SOLUTIONS LTD.
Company Position Title: CEO
Country: Vietnam
Skype Name: tigon_my_love
Post by hsnguyen » Fri Apr 20, 2018 11:45 am
Hi Malte,
i sent you PM already, sure we can help you.
we can discuss more in skype.
Regards
Rainer
gilles_3Dreshaper
Post by gilles_3Dreshaper » Fri Apr 20, 2018 1:49 pm
Hi mate,
Then, the idea would be to compare 2 sections.
1st section would be the one delivered by the drawing department.
2nd section would be a section cut of the point cloud in the plane of the 1st section
Gilles
3DReshaper Manager
Arctanx
Full Name: Anthony Crowley
Company Details: Crowley Pipeline and Land Surveying
Company Position Title: Vice president
Post by Arctanx » Sat Apr 21, 2018 12:50 am
Hi Malte,
Regards
Rainer
So how did you help? I'm curious about this process.
isaackendall
Full Name: Isaac Kendall
Company Details: Scanforce
Company Position Title: co founder
Skype Name: isaackendall
Post by isaackendall » Sun Apr 22, 2018 11:33 pm
I'm curious too! I have the same issue with comparing point clouds to Revit. At the moment, I use Navis works to bring both the point cloud and Revit model in and then cut sections and manually compare.
MalteHC
Country: Norway
Post by MalteHC » Mon Apr 23, 2018 7:32 am
Hi mate,
But how would you do this in reshaper, step by step?
gilles_3Dreshaper
Post by gilles_3Dreshaper » Mon Apr 23, 2018 8:07 am
I would start step by step. And then, if everything seems ok, would write a script to create the sections and run the inspections
If possible on your side to share some data, I can have a look and start writing it...
Gilles
3DReshaper Manager
MalteHC
Country: Norway
Post by MalteHC » Mon Apr 23, 2018 10:05 am
Yeah, but im not sure what tool you would use?
Could you explain how you would do it, step by step?
Return to “Modeling Software”
