So, what's new? The new checkerboard stickers are available in two versions:
Removable checkerboard stickers (item no. 030-11659])
- with black imprint "removable checkerboard target"
- These stickers can be removed without leaving any residue.
- with red imprint "non-removable checkerboard target"
- These stickers adhere permanently and can be used even for longer lasting projects.
What are the characteristics of both stickers?
- Easy application
- Adhesion also on porous surfaces
- Resistance to moisture
- Best reflection properties
- Dimensions: 15cm x 15cm
- Optimum scanning results at ranges of up to 20m (depends on selected scanner resolution)
- The checkerboard stickers are available in our online shop as sets of 50.
