Pipe alignment tool added to Scan To BIM Revit add-in
Discuss all SCAN TO BIM related issues here.
neeravbm
I have made 100> posts
Full Name: Neerav Mehta
Company Position Title: CTO
Post by neeravbm » Wed May 09, 2018 7:52 pm
We've just added the ability to align two pipes in Revit using our Scan To BIM add-in.
Problem description
Revit will not connect two pipes that are not in the same plane. Pipes extracted using the Scan To BIM Revit add-in will fit very well with the point cloud but they may not be exactly in the same plane. The new tool to align two pipes moves a pipe slightly so that they are in the same plane. Then you can connect them in Revit as you usually do.
If you are interested in testing it out, get a free 7-day trial from https://scantobim.xyz.
Below is a demo of how you can extract pipes from point cloud, align them and connect them in Revit using the Scan To BIM add-in. If you are already using pipe extraction and are only interested in seeing the demo of pipe alignment, then forward the video to 1:51 mins.
youtu.be/VO31aI87txQ
Neerav Mehta
CTO, Indoor Intelligence
Return to “SCAN TO BIM”
