Artec texture files to Rhino V5.0
DotProduct DPI-8S &DPI-10, Artec3D, ASUS Xtrion, Creaform G0-Scan, FARO Freestyle, Noomeo, Mantis Vision, ZEB1, Kinect, THOR3D, etc
Dusty
Full Name: Victor Jason
Company Details: 3D Pro Reverse Engineering Pty Ltd
Country: RSA
Post by Dusty »
How do I export or save Artec Eva files (once processed and texture applied) in the correct format so that it can be opened in Rhino, including the texture? :?:
Thanks!
Mike Annear
Full Name: Mike Annear
Company Details: Mike Annear
Has thanked: 7 times
Been thanked: 28 times
Re: Artec texture files to Rhino V5.0
Post by Mike Annear »
If your textures are coming through into Rhino it must just be a display issue.
Have you tried switching to Rendered view in the viewport settings ?
What format did you use to import the file into Rhino 3D ?
I usually use an OBJ file with textures, Rhino will read the MTL file that is made with the OBJ.
Mike.
Mike Annear
www.mikeannear.com
QLD, Australia.
Return to “Hand Held Scanners”
