Hello
How many of you realize scan under very hard conditions ( dust / humidity / heat / cold ....) ?
Which kind of scanner is the most appropriate ?
I used ZF Imagers / Leica HDS and I got ( and still get ) issues when temperature is too warm or too cold ...
And dust can make pointcloud quite noisy ....
Riegl are known as very best in this area . What about other scanner ?
Olivier
scanning in hard conditions
- Full Name: olivier boissard
- Company Details: GGC
- Company Position Title: laserscanning surveyor
- Country: France
- I have made 50-60 posts
- Full Name: John Halifax
- Company Details: Mining Surveys UK Ltd
- Country: uk
- Skype Name: john_halifax
Re: scanning in hard conditions
Hi Oliver,
We have a Riegl VZ-1000. I have just undertaken a number of scans in extremley dusty conditions, on one day it was so dusty the scan would not penetrate it. I have not used the scanner in anything lower than -1deg but I understand that the scanner will operate at -40deg.
Regards
John
Regards
John
- 15
- Full Name: James Rye
- Has thanked: 28 times
- Been thanked: 69 times
I've used the Faro Photon in very dusty and hot conditions, but I'd think twice before using a C10 as it has fans that suck in the air to keep it cool.
We had trouble using the old Scanstation 2 in cold temperatures. We blasted it with warm air in the footwell of the car and this brought it back to life. It was only about 0 to minus 2 degrees centigrade!
- mmarsault
- Full Name: Matthieu Marsault
- Company Details: Murphy Surveys Ltd.
- Company Position Title: Laser Scanning Manager
In case of cold temperature, with a 6000/7000, I keep the scan ON as long as possible in a warm place before starting working in cold.
- Country: France
I know what you mean .
I recently had problem with overtemperature and It take me more time to cool down the scanner that to do scans itself ...
But it is the reason of my question
I have enough to spend most of my time in other thing than scanning when I have a scan project to do.
It is usually complicated enough to realize ...
Olivier
Olivier
