Scanner fulfilling specs
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Post by max72 »
On a document about a survey to be performed I found the following specs regarding a laser scanner:
precision @ 50m : 1.65 mm
horizontal angle 0.0017 gradian
vertical angle: 0.0014 gradian
1.000.000 points per seconds.
It evidently comes from the spec sheet of a scanner. I'm wondering which one.
Any suggestion is welcome.
stevenramsey
Full Name: Steven Ramsey
Company Details: 4DMax
Skype Name: steven.ramsey
Has thanked: 15 times
Been thanked: 14 times
Re: Scanner fulfilling specs
Post by stevenramsey »
A fictitious one. :D
Steven Ramsey
Home [email protected]
Work [email protected]
Mobile +44 7766 310 915
max72
Post by max72 »
Not sure..
I guess they extrapolated some partial data from a datasheet with no real understanding of the specs.
